Dometic RM 2553 Thermostat replacement
Submitted: Thursday, Apr 04, 2013 at 14:52
176airdispatch
Has any body out there replaced the thermostat in their Dometic RM 2553?!
If so could you please let me know how you did it.
I have the replacement thermostat and I am not near a township at this point in time to trot into a refrigeration workshop and I really don't want to pack up and then reset up later if there is a refrigeration mechanic in town.
Any genuine help will be appreciated.
Best Regards
176airdispatch
Reply By: Member - Charlie M (SA) - Thursday, Apr 04, 2013 at 22:25
176airdispatch
Had to replace the 240volt heating element in ours a couple of weeks ago in the field. Could get to that from the outside bottom vent, bit difficult but do able.
Not sure if you may need to take fridge out to do thermostat. Can not remember if you can see themostat switch from outside vents.
Our fridge would only work on 12volt and gas, no thermostat on those two systems, only on 240volt. New element had it working again as new.
Wiring diagram was on fridge at bottom vent hope this may help.
Hope all goes
well in your replacement.
Charlie
508206
Follow Up By: Member - Charlie M (SA) - Thursday, Apr 04, 2013 at 22:27
If you need a new element it is a 195watt one
Charlie
785641
Reply By: SuperGrover - Friday, Apr 05, 2013 at 00:31
Hi Beware there is 240 volts on the thermostat terminals! I replaced
mine in January myself. There are two different types of thermostats. One with screw in gas fittings and one with push in plug type.
Mine was the screw in type.
I am no brain surgeon but managed to swap it over without too much effort. I did pull the fridge out to access the thermostat and run the sensor tube down the back without damaging it. Beware there is 240 volts on the thermostat terminals!I will not give any advice on the electrical connections. However make sure you unplug the caravan from the mains before you attempt touching the thermostat.
Seller: wash_fix ( 467 )
Item title Price Postage price Qty Item total
Electrolux/Dometic gas/electric fridge Thermostat ( 150743399884 )
Paid on 28-Jan-13 AU $130.00 AU $8.00 1
Subtotal AU $130.00
Postage and handling AU $8.00
Total AU $138.00
508221
Follow Up By: 176airdispatch - Saturday, Apr 06, 2013 at 10:15
Thanks guys for the help, I have a mate who are travelling with us and he had previous trouble with his element, and after checking that another guy came over with his multimeter gear and confirmed that it was the thermostat causing the problem but said he had no idea how to replace it, however he did suggest joining the
forum as he said if there is a problem some one has already dealt with it.
At the present moment the fridge is working fine on gas so I will replace the thermostat when I get
home in two weeks.
I will post a thread after replacing the thermostat and let any else know what difficulties I run into if any.
Best Regards
176airdispatch
785810
