Flexible gas lines
Submitted: Monday, Mar 11, 2013 at 12:28
Member - peter w2 (VIC)
Are flexible gas lines permitted/legal.
Reply By: member - mazcan - Monday, Mar 11, 2013 at 12:49
hi peterw2
in what situation are your queiry's related too????????????? i bet i'm not the only person wondering??? more imfo in your thread is needed
my house gas ng heater has a flexible hose conection to the wall banette
my outdoor lpg bbq has a flexible hose connection to the gas bottle
and my new westinghouse underbench oven i bought saturday also has a flexible gas hose to connect it to ng
whereas my old chef u/bench oven had a fixed cooper pipe connection so in those situations mentioned here in wa they are all legal
506558
Follow Up By: Member - peter w2 (VIC) - Monday, Mar 11, 2013 at 13:07
sorry I am referring to a caravan set up
783546
Reply By: Rockape - Monday, Mar 11, 2013 at 13:14
Peter,
mine has a flex line from the bottle to the regulator. That was from the factory and with gas certificate
506562
Reply By: Notso - Monday, Mar 11, 2013 at 14:37
Hope they are because
mine are flexible, stainless braided hose.
506569
Reply By: moamajohn - Monday, Mar 11, 2013 at 14:53
Peter try walking around a caravan showroom or
park for goodness sake .! Of course they are legal ,but like many applications they have limits re regulations so try asking what you are on about. .
506571
Follow Up By: Hairy (NT) - Monday, Mar 11, 2013 at 15:36
Geeze!!!! Get out of the wrong side of the bed did we....LOL
783568
Follow Up By: JAMES B - Monday, Mar 11, 2013 at 22:00
Geeez is right Hairy! A simple question moamajohn!
783615
Reply By: Member - Bruce C (NSW) - Monday, Mar 11, 2013 at 15:31
Honest enough question there Peter.
Tha answer is too right, provided they are made for gas and not
water.
You probably can't mix them up any way as the gas ones will have a POL fitting in one end easily signifying it is for gas.
Ignore the angry negative responses, they are irrelevant.
Some people do not know how to be polite.
Cheers, Bruce.
506580
Reply By: bluefella - Monday, Mar 11, 2013 at 15:37
G'day Pete
any pipes for gas that run under the chassis or internally have to be copper the short flexable line from bottle to conection point is okay. That is unless the regulations have been changed? I doubt it.
506583
Reply By: Hairy (NT) - Monday, Mar 11, 2013 at 15:39
Gday,
I think you will find it depends exactly where it is, whether it has mecanical protection or not and what State your in.....might pay to ask a gas plumber to be sure.
506584
Reply By: Member - peter w2 (VIC) - Monday, Mar 11, 2013 at 17:02
thanks for the replies polite and rude I suspect the limit is 1M,,but surely a joiner is available,,and if the line was in a casing to protect from
debris and allowed a flow of air it would be safe,,i will check out the rules and will report back during the week
506590
Follow Up By: Member - Duncan W (WA) - Tuesday, Mar 12, 2013 at 22:12
Peter I've seen long than 1m lengths available at BCF. Guy said it was so you could leave the bottle on the roof rack and still be able to reach most portable stove set-ups. Length I saw was 2m or more and no regulator. Was also told (true or false?) that a regulator is only required if the bottle is part of a fixed stove set-up like in a camper trailer or caravan.
783719
Follow Up By: Member - Scott M (NSW) - Tuesday, Mar 12, 2013 at 23:44
sort of true - as long as it's not permanently connected and the gas source isn't in a confined space....
783726
Reply By: Tim - Monday, Mar 11, 2013 at 19:21
Fair question, among other things including mechanical protection factors in areas likely to be disturbed/damaged, I think there is a length restriction and I thought it was around the 2m mark. Either way, I am interested in the correct answer as I am in the process of re-running some gas lines on the camper also.
Tim
506592
Reply By: Member - peter w2 (VIC) - Monday, Mar 11, 2013 at 19:33
what part do the 3 twists in the gas line play
506593
Reply By: rags - Monday, Mar 11, 2013 at 21:32
AS5601 part 2 is the gas code that your gasfitter would need to be familar with. The length of hose varies depending on where and how they are used. As a guide,
[2.11.1] Hoses shall be of a minimum practicable continuous length .
[2,11,2 ]Hose assemblies shall only be used between the regulator and rigid piping, and between rigid piping and appliance. For caravans connecting pipework between bottle and appliance that exceed 1m shall be made out of a combination of rigid pipe and if required ,flexilbe hose that is connected to the rigid pipe.
[5.2.5] Hose assemblies shall be- [a] of minimum practicable length not exceeding 1.5m - [b] used only between the regulator and rigid piping and between rigid piping and appliances, or where there is only one appliance, directly between regulator and appliance
[5.1.4.1] deals with the requirements of the high pressure piping between the bottle and regulator including hose assemblies.
This info has been provided as a guide only and yes all gasfitting work is covered under various state laws and only licensed gasfitters can work on any gas system so don,t muck around with it as it is not only you who can be impacted when things go wrong but also innocent bystanders .
506601
Follow Up By: Member - Scott M (NSW) - Tuesday, Mar 12, 2013 at 00:14
rags has the best advice ....
check with a licensed gasfitter.
I remember asking a similar question of my local gas fitting supplier regarding flexible hose from my external gas bottle to my internal stove... this guy knew what he was talking about and launched into a detailed description of regulations regarding distance, high/low pressure, and external vs internal hose fittings .... in the end he looked at me rather exasperated and said, basically get a proper gas fitter to assess and do it !!! easier in thel ong run if you want to stay legal....
783621
Follow Up By: Bazooka - Tuesday, Mar 12, 2013 at 11:58
"gasfitting work is covered under various state laws and only licensed gasfitters can work on any gas system so don't muck around with it as it is not only you who can be impacted when things go wrong but also innocent bystanders."
This should be a standard disclaimer added to every thread about gas.
783642
Follow Up By: Member - peter w2 (VIC) - Wednesday, Mar 13, 2013 at 09:43
I have been to the gaseous man,,,he tells me that rigid pipe encased in hose or similar is required to protect the gas line from damage where it runs external to the chassis
Flexible line is ok between appliances/bottle and the rigid gas line
In vic. you can do your own gas work on a van,,but it must be inspected by a gas fitter to have a certificate issued l
783740
Reply By: Member - mepvic - Friday, Mar 15, 2013 at 17:46
I have just fitted the third gas regulator to my camper trailer. It's a two stage one and has a flexible line from the bottle to the reg, and from the reg to the stove.
Thought after two failures, I would contact the regulator man to see if there was an issue with the mounting or type of unit being used. Shouldn't be failing that often.
Interesting response. They are saying that flexible lines to the gas regulator are being damaged by the gas. It is causing a black goop to form inside the regulator as a result of the rubber in the flexible line breaking down and this in turn is damaging the diaphragm in the regulator. In some cases in 6 months.
Recommendation is to avoid flexible lines from the gas bottle to the regulator. I have just fitted a copper line from each bottle through a line 1/line 2 switch into the regulator. Have formed a pigtail in both lines to the bottles to give some flexibility and to assist when removing bottle for refill.
506844
Follow Up By: Member - peter w2 (VIC) - Friday, Mar 15, 2013 at 19:24
Hello are you sure it is flexible GAS line, there are other types petrol, diesel, water. most bbq,s have a rubber line and dont seem to have any problems,,,i am using the same line as on a bbq cept it doesn't have the shiny flex metal covering which is there to protect the rubber line,,,i intend to enclose the rubber in aanother hose Peter
783977
Follow Up By: Member - mepvic - Friday, Mar 15, 2013 at 20:02
My problem is the flexible gas line connected to the regulator. The regulator is remote from the bottle and is being damaged. BBQ's have the regulator directly screwed into the bottle so don't have the problem.
783979
Follow Up By: Member - peter w2 (VIC) - Saturday, Mar 16, 2013 at 06:34
my reg is screwed to the bottle,, maybe that is what you have to do
784002
Follow Up By: Member - mepvic - Saturday, Mar 16, 2013 at 09:31
Can't do that and it wouldn't fit anyway.
Regulators and installations for trailers and caravans needs to comply with gas regulations for fixed appliances. Regulator is a two stage one mounted vertically so dust and water do not get into the vents.
784006
