Chescold Dometic RC1180 - not cooling well on gas
Submitted: Sunday, Feb 17, 2013 at 11:54
ThreadID: 100593 Views:6802 Replies:6 FollowUps:1
I've recently come into possession of a 2nd hand RC1180. It's about 5 years old and looks to be in pretty good nick.
It cools brilliantly on 240v - down to -15º, but on gas it sits arounds +9º. Ambient temp is is 29º.
I've done the usual things - ran for 48 hours on 240v and have the unit perfectly level in a shaded spot.
Should I look at getting it serviced, or is this as good as the fridge gets?
Reply By: DiscoTourer - Sunday, Feb 17, 2013 at 12:18
At that ambient temp, it will definitely go much lower. Could be a gas blockage or flow rate not quite right....would be worth getting it checked out.
Betty....
AnswerID: 504927
Reply By: MEMBER - Darian, SA - Sunday, Feb 17, 2013 at 14:19
Gas out-performs the other modes in 3 ways - must be a snag with the flame function - a speck of dust in the lines when connecting is all it needs (the jet hole is microscopic) - if you can clean out the jet and lines you'll probably be right (but you might need a specialist service).
AnswerID: 504935
Reply By: passionfruit - Sunday, Feb 17, 2013 at 16:30
Most likely the gas jet needs cleaning or the gases in the fridge it self need a goo shake up.
AnswerID: 504940
Follow Up By: passionfruit - Sunday, Feb 17, 2013 at 16:32
Should read 'good' shake up.......
FollowupID: 781828
Reply By: nickoff - Sunday, Feb 17, 2013 at 16:36
I too have had this issue in the past. Turned out to be dust and cobwebs etc on the burner itself. Have a look at the flame, should be small, neatly shaped and blue. If it is odd shaped and or yellow tinged, could be a blocked jet, blocked air inlet, or a dirty burner. Clean all carefully. Also check the chimney for blockages or crud disrupting the heated airflow through the boiler.
AnswerID: 504941
Reply By: Ron173 - Monday, Feb 18, 2013 at 12:29
clean the flue
AnswerID: 504991
Reply By: MattJ - Wednesday, Mar 06, 2013 at 09:10
Just wanted to thank everyone for their replies. I cleaned the flue, burner and jet and now the fridge is getting below -10º in 30º ambient.
AnswerID: 506160
