Pajero Battery .
Submitted: Saturday, Feb 16, 2013 at 18:18
Member - 2517.
Have just brought a 2009 Pajero and was wondering what the biggest battery you can put in, it is diesel.
Reply By: DiscoTourer - Saturday, Feb 16, 2013 at 19:26
Are you talking a cranker or auxiliary battery ?
Maybe measure the tray length and width, then height and pop into your local battery guy and tell him what you are after.
Brett....
504885
Reply By: patsproule - Sunday, Feb 17, 2013 at 07:54
Factory tray can take an NZ70, which if you have a diesel is what it should be fitted with. Petrols often had a smaller battery in the large tray. If you want to go to dual batteries there are several trays available. The ARB one can take an NZ70 and a smaller battery (smaller than an NZ50). There is an Opposite Lock "police spec" one that allows two NZ70's but space is tight. I have the ARB tray in
mine with an Optima red top in the rear aux (small) position but have moved the factory cables to make this the start battery. This allows me to run a 1005AH NZ70 deep cycle as the Aux battery. The compact Optima has the same CCA rating as the factory NZ70 albiet with a reduced RC rating. In practice it's no issue.
504910
Follow Up By: patsproule - Sunday, Feb 17, 2013 at 16:13
1005 = 105 AH of course....
781825
Follow Up By: Member - 2517. - Monday, Feb 18, 2013 at 10:41
Thank you for your reply that's at great help I will look into it.
781892
