IsatPhone – Feb 2013 another mandatory update
Submitted: Sunday, Feb 10, 2013 at 12:46
Dennis Ellery
IsatLatest firmware version 5.3.0 released on 8 February 2013. This is a mandatory firmware upgrade. To
check you have the latest version on your IsatPhone Pro, go to Menu > Settings > About > Firmware version.
Download IsatPhone Pro firmware version 5.3.0
IsatPhone Pro firmware 5.3.0 release note
Reply By: Member - Cozzie Toodyay (WA) - Sunday, Feb 10, 2013 at 16:14
Hears hoping they got it right this time Dennis.
Cozzie
504471
Follow Up By: Dennis Ellery - Sunday, Feb 10, 2013 at 16:26
It will never happen - computer programs just keep moving along.
781300
Reply By: wombat100 - Sunday, Feb 10, 2013 at 18:11
Hiya Dennis
Mine shows v4.0.0.
What differences would I notice with the updated versions???
And how do I update to the latest version???
Wombat
504474
Follow Up By: Dennis Ellery - Sunday, Feb 10, 2013 at 21:06
I imagine your phone will die sometime around July this year.
I will look at my notes and get back to you tomorrow
781320
Follow Up By: Member - Stephen L (Clare SA) - Sunday, Feb 10, 2013 at 21:23
Hi Wombat
Please excuse me for butting in, but it is dead easy. Here are two links that explain how it is done. As you can see, you must install the drivers first, and then the Firmware Upgrade Tool. Then select the new firmware version date you must also download, 5.3.0 and then do as the demonstration advises you what to do.
First Link, better Volume
There is the second link that has all the downloads that you will require, the Drivers download, the Firmware Upgrade Tool, but the wrong firmware version.
Drivers and Firmware Upgrade Tool downloads
Here is the link for the latest 5.3.0 Firmware download.
The latest 5.3.0 upgrade zip file
781323
Follow Up By: Dennis Ellery - Sunday, Feb 10, 2013 at 21:26
Sounds good to me - give me another post if you get problems.
781324
Follow Up By: Member - Michael K (WA) - Monday, Feb 11, 2013 at 12:17
My attempt at upgrading the new firmware V 5.3.0 was successful. I must give credit to suggesting First Link, better Volume. This easily helped me through the process in a very short time.
Michael
781352
Follow Up By: wombat100 - Monday, Feb 11, 2013 at 19:00
Thanks Dennis & Stephen
All done...and guess wot !! The phone still works !!
781379
Reply By: Member - Stephen L (Clare SA) - Sunday, Feb 10, 2013 at 21:06
Hi Dennis
Thanks again for that important news. Just as
well as I had the required items for the upgrade, so I just installed the latest firmware upgrade and did as I did a couple of weeks ago.
As the file size is slightly larger, it took a little longer to install. It was not as plain sailing as last time, as when I took the phone outside to make sure all was sweet, it locked on to the satellites as normal, but them came up with an error message, "can not make contact, please contact your service provider"
I then though what am I now in for, and then pressed the search button again, and it all worked as it should, including the free
test phone contact and my balance phone call.
504492
Reply By: Olsen's 4WD Tours and Training - Sunday, Feb 10, 2013 at 22:44
Thanks so much for the update
504501
Follow Up By: Olsen's 4WD Tours and Training - Sunday, Feb 10, 2013 at 22:55
What a shame they don't support real computers :-) only Windoze machines.
781333
Follow Up By: The Explorer - Tuesday, Feb 12, 2013 at 02:23
...another handy notification for people who live in the 'real' world, don't rely on a Mac :)
781398
Follow Up By: Olsen's 4WD Tours and Training - Tuesday, Feb 12, 2013 at 08:02
That leaves us in a quandry because you sure can;t rely on Windoze :-)
:-) If you live in the real world you cant rely on a computer at all, you can't rely on a Satphone either :-)
781402
Reply By: Member Andys Adventures - Monday, Feb 11, 2013 at 10:19
Hi Dennis,
The upgrade is not mandatory it is only if you have trouble charging the phone after it is switched off and the battery goes flat. If this happens you can not turn it on or charge the battery unless you charge it with 240 mains power.
Have been given 2 new phones in 18 months because of this problem. They have found a problem with the firmware and now have upgrades to fix problem.
This from my supplier:
Dear Customers,
We have been recently advised by Inmarsat that there is an issue with IsatPhone Pro's purchased since September 2012 running firmware versions 5.1.0 & 5.2.0 (the latest).
Inmarsat has discovered that these two versions of firmware contain an error causing the battery not to charge whilst the phone is switched off. If the battery is allowed to run flat, then it becomes impossible to charge the phone unless a new, pre-charged battery is fitted.
Inmarsat's engineers are producing a new version of firmware which will resolve this problem. We anticipate that this will be fully tested and available for release by 8th February 2013.
In the meantime, our customers should be advised to have the phone switched-on during charging and to maintain a full to half charge until their IsatPhone Pro has been upgraded with the new firmware.
We will contact you the minute the firmware upgrade becomes available.
504514
Follow Up By: Dennis Ellery - Monday, Feb 11, 2013 at 10:47
Hi Andy,
Inmarsat say its mandatory - thats good enough for me.
781348
Follow Up By: Sigmund - Tuesday, Feb 12, 2013 at 08:28
Inmarsat are going to make a change to the network system so when that happens earlier versions of firmware will prevent the phone from working.
But the change has been pushed back to the end of the year.
781403
Reply By: Member - Trouper (NSW) - Monday, Feb 11, 2013 at 12:26
I'm really glad your phones are working OK But if you hadn't bought cheap a**ed phones with dodgy satelite systems you would not have had the problem in the first place. Image all the poor people who dont know of the 'upgrade'
If you had bought a Motorola operating on the Iridium system you would have no problems. Yes I know there bloody expensive (But you only get the amount of quality you pay for). As an example I fired up my phone last week for the 1st time in 7 months and presto full signal in less than 30 seconds. Now I sit back and wait for the 'responses'
Jeff
504519
Follow Up By: Member - Duncan W (WA) - Monday, Feb 11, 2013 at 16:06
Jeff the satelite connection is not the problem. The phones connect very quickly.
781370
Follow Up By: Dennis Ellery - Monday, Feb 11, 2013 at 22:25
Hi Jeff - Having a bad hair day mate.
Besides being cheaper Inmarsat has a number of features that Iridium doesn’t have.
Here is a comparison.
http://www.epirbhire.com.au/Compare%20Iridium%20and%20Inmarsat.htm
781392
Follow Up By: Member - Trouper (NSW) - Tuesday, Feb 12, 2013 at 12:26
Yeah guess you could call it that. Was just trying to get a reaction and spark up the site a bit didn't work though did it??
Cheers................Jeff
781418
