Thursday, Jan 24, 2013 at 06:11
How do I work what out?
A WDH is now not used to move the centre of effort from ball weight forward along a chassis? Give me a break.
The key point here is not to 'guess' what's in the tray, or guess if the WDH has allowed the rear to compress a bit. It's to understand how a factory standard ute on factory standard springs with no WDH would sit with the same van on the back and load in the tray. Sagged down like a mangy dog is the most common answer, and in that position braking effort (BIAS) is moved from the front to the rear of the vehicle, and rightly so.
Good braking on the front is inportant, I agree, but when performing an emergency stop towing a big trailer and ONLY the fronts lock up or work because the bias valve won't allow the rears to grab, how do you think it's going to end? Believe me, I've found out the hard way how they work/don't work, as have plenty of others, hence why the actuator gets cable tied to the chassis when towing with modified
suspension, airbags, WDH's or anything else that does not give a true indication of how much traction is available to the rear wheels.
NTVRX - I'm not going to tell you what to do, but I'll tell you that my last vehicle ('03 hilux SR5) had airbags on the rear (dual cab, towed all over the country, didn't snap - amazing) which also assist a vehicle to maintain a proper attitude when towing. I will also tell you that it had a 2" lift kit. When I installed the lift kit, I purchased (separately) a brake bias extension which moved the lower (axle) mounting point 2" higher so that braking wasn't compromised when the ute was empty. However, it soon became abundantly apparent that when carrying load, or towing load and using the airbags/HD springs to assist, the lack of rear bias made the vehicle dangerous. From then on, when towing any distance, it was common place to undo the brake bias arm and cable tie it up under the tray. The difference had to be felt to be believed.
In your case I believe this argument will be moot, as I am pretty confident that if you have ABS, you get EBD and BAS anyway in the D40's.
779918
