Friday, Nov 13, 2009 at 00:11
G'day Tony,
no offence mate, but the advice you gave in your post (above) is 100% contradictory to what I was advised, by Land Rover Australia, to do when towing with and automatic Disco 3.
I specifically contacted them when I purchased my vehicle because I had heard many stories of "blown" auto trannies in all makes of vehicle.
Land Rover's advice is as simple as "put it in drive and the transmission will take care of itself". They specifically advised AGAINST using the manual mode of operation when towing.
The reasoning is that the trans is both adaptive and intelligent. It interacts with the engine ECU to ensure that the right gear and the right revs, fuel mix etc are made available to keep the gearbox within its operating parameters at all times. They argued that locking the trans in a specific gear would heighten the risk of overheating the transmission.
We pull a 3.5 tonne 'van and have done 83,000 trouble-free Kms so far. I don't know the circumstances of the trans failure that the original poster had but I do know that in the 6 months I spent working at a Land Rover dealer last year, not one D3 came in with transmission failure.
ZF are so confident in the transmission that they manufactured it so that you cannot
check or top up the trans fluid and it is not checked by a dealer until the vehicle has done over 200,000 Kms.
It will be interesting to see a follow-up post about this issue once they have determined what went wrong.
Russ
658912
