91 troopy air con
Submitted: Sunday, Jan 01, 2006 at 00:15
cooper127
The air con in the old girl is not what it used to be. Had the gas changed and charged but is still not like before. I gently prised apart the plastic cover(about 12mm) for the condenser and found it totally blocked with dust , fluff and god knows what else. Is there an easy way to clean it rather than pull the whole dash out .
Thanks Have a great new year
Reply By: Member - Geoff M (Newcastle) - Sunday, Jan 01, 2006 at 00:24
Compressed air and clean up the dust storm later.
Also a reamr for the people who continually charged you for the re-gas. Perhaps they should have noticed no matter how much gas they used, the world didn't change.
Geoff.
| Geoff,
Landcruiser HDJ78,
146138
Reply By: Peter 2 - Sunday, Jan 01, 2006 at 13:31
The cheats way is to work out where everything is inside by visiting the wreckers and either pulling one apart or looking at the disassembled unit.
Then carefully drill a hole (50mm if possible) in the plastic duct with a hole saw. Vacuum the crap out, refit piece drilled out with silicone to seal the gaps.
I've done this on a few cars where the a/c/heater assembly comes down the assembly line hanging on a bit of wire and the rest of the car is built around it!
146181
