Friday, Dec 30, 2005 at 17:08
Mick, you don't seem to be out of your depth.
You should post your questions again when the 'luminaries' are around as there are some forumites who specialise in these sorts of things.
I used to go bush without even a fridge...lol....but times change. Still, I try to keep it simple though.
I have 2 Overlander 700cca cranking batteries in parallel through a solenoid ( I started off with a Rotronics Battery management thingy but it died)
I have a 150watt Pure sinewave inverter which is good for charging batteries including that of a laptop. However, I run the laptop off a Kerio DC powersource out of the cig socket. (This is after trial and error with the inverter). I run a mechanics fluoro light off the inverter with an 11watt globe. Enough light for us.
Q1. Not sure what the advantages are of running a gennie through a Battery Charger. My old genset has a DC charging outlet as
well but I dont use it any longer.
Q2. For the fridge (32lt Engel) I use the DC fridge cable into a cig socket which is hardwired with 6mm wire. Never have a problem
Q3. Can't help you there as it is out of my field of knowledge..lol
Q4. If you are taking a gennie then an inverter is not needed
I only use my laptop for photo downloads, daily diary and the occasional time when I connect to the GPS when I am uncertain of my position. I don't have it running all the time.
I prefer to stay out in the bush but normally organise my trips so that I would stay a max of two days at a site. We don't really need the fridge except for daily milk and cold water( don't carry beer out bush..too cumbersome). Once we have eaten our fresh meat supply the fridge is only used for drinks, butter etc.
I have now upgraded to towing an Offroad Box trailer so that all the camping stuff comes out of the truck. We still tend to take too much with us. :o)
399554
