Saturday, Jan 07, 2006 at 18:50
Craig, Andrew here. I'm sorry I haven't been able to get back to sooner.
An aluminium cored radiator will cool more efficiently than a copper/brass one. The copper is efficient in transferring heat but the solder used to hold everything together is terrible.
Your current radiator is 25mm thick but that will be one row of tube and that tube is the whole thickness of the radiator so that's 25mm. On your quoted one of 32mm thick copper/brass that will be 2 rows of tubes but to fit them into a core thickness of 32mm and allow tube to tube clearance then each tube is only going to be 12mm -13mm deep so there's no benefit there in coolant volume.
For a full custom fabricated aluminium radiator I can't even buy the cores for what your buying the complete standard radiator for. For example the custom core for my GQ cost me a little under $600 when I bought it and then there were mega hours of work to finish it off.
My best advice to you is to start with the cheapest things 1st. Replace thermostat, you never know you may have a "lazy" thermostat it can happen.
Next, put a good quality radiator flush (I like Tectalloy Muckowt) through the system and follow directions and flush out your entire cooling system and then get it reverse power flushed by a radiator centre. You'll be amazed just how much gunk is flushed by a high volume reverse flush.
If it were me I would then either remove the radiator myself of have it removed and have a radiator
end tank taken off and have the core "rodded" out this will clean out any blockages which may be in your core and have a new tank O ring fitted and the tank replaced on your core. You can usually remove a tank twice before there are any problems with resealing the tank to the core.
That's the direction I would go 1st, it should be the cheaper option.
As an example, my day job is in the motor racing industry and the sprintcars we repair and manufacture are producing between 700- 750 bhp and they use a radiator core of 25mm thickness and don't have cooling problems. There is one caveat though and that is that they run on Methanol which is a "cool" fuel. The supercars use a core thickness of 40mm on their sprint rounds and 57mm at
Bathurst.
Regards Andrew.
400474
