Removing Tar
Submitted: Thursday, Dec 29, 2005 at 14:30
ThreadID: 29235 Views:6016 Replies:12 FollowUps:3
G'Day all,
On my last road trip, I had to travel on a piece of road still under construction. As a result, I now have bits of tar on a number of panels on the Hilux.
I was wondering what is the best method of removing the drops of tar? As such, I'll have to cut and polish because the methods I have so far used have resulted in a noticable difference of colour between where the tar was and the rest of the panel.
Reply By: big red car - Thursday, Dec 29, 2005 at 14:43
hi ray,
try kero,diesel, or even baby oil, thay should all help,
johno.
AnswerID: 145879
Reply By: brd - Thursday, Dec 29, 2005 at 14:49
Hi Ray
Did you try a little diesel on it? This will dissolve the tar easily, and shouldn't affect the paintwork, as it doesn't seem to worry it when refuelling spills occur. Better than cut & polish and dead easy.
AnswerID: 145880
Reply By: Bronson - Thursday, Dec 29, 2005 at 14:59
Try CRC Spray, It works a treat and dissolves it instantly
AnswerID: 145882
Reply By: Bob Y. - Qld - Thursday, Dec 29, 2005 at 15:06
eucalyptus oil.
AnswerID: 145884
Reply By: Member - Ray (SA) - Thursday, Dec 29, 2005 at 15:11
Thanks guys, plenty of suggestions. I'll try some of these and see how they go.
AnswerID: 145885
Reply By: Sarg - Thursday, Dec 29, 2005 at 15:23
I have found that Nu Finish polish will do both jobs at once, depending on how big the tar splotches are.
AnswerID: 145888
Reply By: Nudenut - Thursday, Dec 29, 2005 at 16:26
shellite, petrol, white spirit, mineral turps, pure turpentine, and all of above
AnswerID: 145906
Reply By: Mike DiD - Thursday, Dec 29, 2005 at 17:52
Turps is what they put in commercial Tar & Bug Remover.
The other part is Cloudy Anmmonia (available from Coles Cleaning Dept) - dissolves bugs with no rubbing.
Mike
AnswerID: 145912
Follow Up By: Member - Allan M (ACT) - Monday, Jan 02, 2006 at 18:18
Any idea whether cloudy ammonia causes damage to paintwork or plastics on vehicles?
FollowupID: 399857
Follow Up By: Mike DiD - Monday, Jan 02, 2006 at 18:43
I've been using it for decades on the front of the car - never affected duco, rubber, plastic or chrome-plated plastic.
It's a mild enough alkali to use on bare skin - shame about the smell !
FollowupID: 399862
Reply By: robbo72 - Friday, Dec 30, 2005 at 07:23
hi ray
i am a spray painter and i am not sure if i would be using a few of the methods above on my paint work,goto your local automotive paints distributor and get a product called prepsol or de-wax(same stuff,different label)it is designed to be used on paintwork and is about $10 a litre.
cheers andrew
AnswerID: 145970
Reply By: Ron173 - Friday, Dec 30, 2005 at 07:49
Easiest cheapest most readily available one not mentioned yet.... margerine, it disolves it easily, then a wash removes the marg left over, also you can usually do this one in camp on the night it was 'tarred'
Ron
AnswerID: 145973
Reply By: P.G. (Tas) - Friday, Dec 30, 2005 at 08:42
G'day Ray, I used to work on a road sealing crew a few years ago and used to take great delight in watching the new guys trying to get bitumen off the skin after work. They usually ended up looking like lobsters after trying to scrub it off.
The secret is baby oil. Wipe it on liberally, leave for 5 minutes and the bitumen will wipe off effortlessly. Works on skin and painted surfaces just the same.
AnswerID: 145975
Reply By: Member - Kingsley N (SA) - Friday, Dec 30, 2005 at 10:00
How about the problem when you get tar on your carpets/mats?
I have tried a number of solvents (turps, metho etc) and supemarket carpet cleaners (Preen, Chem dry) but I still have brown smudges.
It looks like replacement mats for me.
Kings
AnswerID: 145981
Follow Up By: Member - Kingsley N (SA) - Monday, Jan 02, 2006 at 18:45
Can anybody help with ideas to get tar off carpets?
Kings
FollowupID: 399863
