Tyre Sizes, Again!
Submitted: Thursday, Dec 29, 2005 at 11:54
Snowy 3.0iTD
I know this issue has been done to death on this
forum so I will cut straight to the point. After speaking to Nissan Australia this morning I have ordered a proper Nissan tyre placcard for 265/75 R16 tyres to sit alongside the original 265/70 R16 placcard. I know it is not a huge increase in size but for $18 the extra flexibility in tyre selection, and money it will save me on tyre purchase price, I consider it
well worth the money. I am not sure what other manufacturers do, but with Nissan if it mentions a tyre size in the manual then you can probably get a placcard for it. Hope this helps some people out there.
Kind Regards
Snowy
Reply By: Hardo - Thursday, Dec 29, 2005 at 12:49
Snowy
What do you need the placard for? Is there a law that states you have to have the correct placard to match the tyres? Isn't there a percentage increase rule? Maybe all the people running bigger than 265/70/R16 are breaking the law?
Hardo
145873
Follow Up By: Snowy 3.0iTD - Thursday, Dec 29, 2005 at 14:02
Hardo
A quick search of this
forum will turn up many threads on this subject, but to set you straight after having done a bit of research on this myself in all states except WA: a vehicle is illegal/unroadworthy if the rolling diameter of its tyres is greater than 15mm above the rolling diameter of the tyres on the ADR approved tyre placard. Hence on a Nissan Patrol with a tyre size of 265/70 R16 (793mm) on the placard it is illegal to run 265/75 R16 (820mm), let alone anything bigger. If you happen to have a major accident where people are injured in an unroadworthy vehicle the consequences are dire.
Snowy
399383
Follow Up By: Hardo - Thursday, Dec 29, 2005 at 14:30
Thanks for the info Snowy
399391
Follow Up By: Exploder - Thursday, Dec 29, 2005 at 20:38
Go WA!!!!
399419
Follow Up By: sudsy - Saturday, Dec 31, 2005 at 13:13
I think you will find that you can go up to 50mm above the rolling diameter stated on the placard with a 4wd vehicle. ( giving a 1" lift)
I think that 15mm rule applies to 2wd passenger cars. This is what I read in the new code of practice anyway.
But then with all of todays "crossover" vehicles and softroaders what defines a 4wd these days?
399643
Reply By: tonysmc - Thursday, Dec 29, 2005 at 19:58
Hi Snowy. I am just about to purchase new tyres so I read your post with much interest. After looking at my tyre placcard it reads 235/75 R15 or 265/70 R15.
Does this mean it is ok to run a 265/75 R15? I did notice you were talking about
R 16's not 15's, so maybe the range isn't as good.
Cheers Tony.
145929
Follow Up By: Exploder - Thursday, Dec 29, 2005 at 20:41
265/70R15, can you even buy that??
I thought after 235/75R15 the measurement changed to Inches I.E LT31/10.5R15
399420
Follow Up By: Snowy 3.0iTD - Friday, Dec 30, 2005 at 08:32
Tonysmc
265/70 R15 is a rather unusual size, I have seen tyres around in this size but wondered who ran them. As for 265/75 R15 I must admit I have not seen them around or heard of them, but assuming you can get them, 265/75 R15 to 265/70 R15:
Tyre width [mm] x Aspect ratio x 2 + (rim size [in] x 26.4 [mm/inch]) = tyre diameter [mm]
265 x 0.75 x 2 + (15 x 26.4) = 793.5mm,
while 265 x 0.7 x 2 + (15 x 26.4) = 767mm,
then 793.5 - 767 = 26.5mm
which is more than 15mm and hence illegal. Which is why I was happy to discover that Nissan do a proper placard for the larger tyres.
Regards Snowy
399485
Follow Up By: tonysmc - Friday, Dec 30, 2005 at 21:25
Thanks Guys, I know stuff all about tyres as I have mostly had 31/10.5R15's, thats why I asked about sizes and I don't know if they even make a 265/75R15 and I was just trying to get some info before laying out the cash. Exploder, as for the 265/70R15's, I have them on the car at the moment and yes you can get them at all the
places I have asked.
Mine are bridgestone Dueler's
Regards Tony.
399570
Reply By: Willem - Thursday, Dec 29, 2005 at 21:04
It had never crossed my mind....but I went to have a look for interests sake and the tyre placard is illegible due to stuff rubbing against it in the glovebox.
The GQ is also rated 265/70/16 but I have been running 265/75/16 for a while now. When I bought it second hand it had 265/75/16 tyres and I did not question it. Thought it was the norm.
It doesn't worry me now however, as if there is a remote possibility of a liability claim against me some time in the future, I will worry about it then.
145933
Reply By: Patrick - Friday, Jan 13, 2006 at 15:00
Snowy 3.0iTD,
RE: Patrol Y61 replacement tyre placard.
My local Nissan dealeris having problems trying to find the tyre placard you obtained from Nissan Australia to cover the 265/75/R16 re-sizing. Are you able to have a look at your placcard and let me know what the part / item number is, so that I can pass this onto my guys. I understand that it is printed on the sticker itself.
Thanks in advance.
Patrick
148315
Follow Up By: Snowy 3.0iTD - Friday, Jan 13, 2006 at 19:46
Patrick
The part number as it appears on my receipt is NI-99090-VB000A, although I don't think you need to quote the NI. Cost me $15.
Snowy
401652
Follow Up By: Patrick - Saturday, Jan 14, 2006 at 03:48
Thanks Snowy.
Problem solved with the dealer being able to now locate the part.
Patrick
401712
