SuperCheap Hand Winch
Submitted: Friday, Dec 02, 2005 at 13:34
Member - Maxwell H (NSW)
Would it be worth buying a hand winch which is made in China from Supercheap which are now on special for $299
Reply By: Sand Man (SA) - Friday, Dec 02, 2005 at 14:51
I would put my faith in something that is
well and truly proven, such as the Big Haul, tested to be at least as good as the more expensive Tirfor.
But when it comes to safety and there is no one else to fall back on, would you "bush test" a product that is unknown?
142137
Follow Up By: Scubaroo - Friday, Dec 02, 2005 at 16:30
Where's the Big Haul made? Just a guess, but if it's China, the Super Cheap Auto
winches could be from the same factory and simply rebadged - much like the ARB Magnum and Terrain Tamer
winches (which are simply the same winch with a different paint job as far as I know).
Might pop into Super Cheap and have a look on the weekend.
395744
Follow Up By: Scubaroo - Sunday, Dec 04, 2005 at 00:10
Had a look at one today, wouldn't touch it. Looked dodgey, was made in China. Walked into ARB and had a look at a Magnum - much better quality. Made in Germany I think - only judging by the German text on the serial number plate.
Super Cheap one I saw wasn't on sale either - $459 versus $395 for the ARB Magnum.
395872
Reply By: myfourby - Friday, Dec 02, 2005 at 14:52
Most of these winch's are made from the same template - I haven't seen one break yet! - the chinamen seem to be good at copying things!
I'd give it a try!
-myfourby
142138
Follow Up By: V8troopie - Friday, Dec 02, 2005 at 15:29
You're right, they are good at copying stuff but lack sadly in metallurgy knowledge.
Often something that looks right has mild steel parts where hardened high tensile is called for. Or the part is brittle when its supposed to be tough.
"give it a try" at
home, where you have a chance to return it if it does not do the job. Not much fun finding out about that out somehwere in the never never land.
Klaus
395739
Follow Up By: myfourby - Friday, Dec 02, 2005 at 15:52
Yep - you're right - I'd
test it under a decent load before I took it out. I'd imagine that such an item would still need to meet some type of Australian Standards to be sold in OZ though - you'd hope safety testing had already been done?... but then I was just looking at the supercheap recall webpage - it appears they have sold items that didn't quite meet OZ standards before!
I'd still give it a try!
-myfourby
395743
Reply By: flappa - Friday, Dec 02, 2005 at 15:25
Why not.
If your life depends on your winch , then maybe you shouldn't be there anyway.
I would give one a shot.
142139
Reply By: brd - Friday, Dec 02, 2005 at 16:58
Yeah
I bought a floor jack from Super Cheap, and it failed to hold a load on its 3rd use. Before I purchased, I asked, and was told it met Aust Stds. I took it back and it was on their recall list.
142152
Reply By: Kiwi Kia - Friday, Dec 02, 2005 at 17:13
Whatever the brand, do not get a hand winch that has only one finger that stops the reel unwinding when under load. Some
winches have a ratchet wheel and locking finger on both sides of the winch drum, some have the holding finger on one side only.
142153
