How to make roads more prominent on ExloreOz Traveller App
Submitted: Sunday, Dec 15, 2024 at 18:37
ThreadID: 149296 Views:437 Replies:4 FollowUps:1
I have found roads on the ExplorOz Traveller app difficult to see. Particularly when zoomed out.
The default is a fine white line, which is hard to see on most driving conditions. and secondary roads are dropped off.
Is there a setting to change road map settings.
Reply By: Member - wicket - Sunday, Dec 15, 2024 at 20:13
Well that’s very odd as all the roads on EOtraveller are red, seems it must be an issue with your setup.
I don’t think you have a genuine copy as looking at the top of your screen it says Traveller when it should show ExplorOz Traveller.
AnswerID: 646951
Follow Up By: ExplorOz - David & Michelle - Sunday, Dec 15, 2024 at 21:51
On phones without room it just shows TRAVELLER. His problem is he is viewing the other map option not EOTopo. He can chsnge this in map layers.
Currently Mapping in the Field Across Australia Fulltime in 2024 - 2025
FollowupID: 927732
Reply By: TrevorDavid - Sunday, Dec 15, 2024 at 20:58
That is the Streets and Paths , adjust to offline maps.
TrevorDavid
dontyajustluvit
AnswerID: 646952
Reply By: ExplorOz - David & Michelle - Sunday, Dec 15, 2024 at 21:49
Your screenshot is showing the Streets & Paths map not EOTopo. Open Map Layers - you have a choice of base maps when online. Offline is always EOTopo.
AnswerID: 646954
Reply By: Member - Phil D13 - Monday, Dec 16, 2024 at 19:29
Thanks for the feedback. That worked!
AnswerID: 646963
