Monday, Jan 22, 2024 at 07:07
Hi Guys,
20 years ago we travelled from
Rainbow Valley through to the Finke/Ghan Road on that track. The gates were not locked back then, and the track between
Rainbow Valley and the railway line had a few overhanging tree branches back then. It did not look all that
well travelled, not sure what it would be like now. We were not towing a caravan back then.
Also, you do not need to go as far South as
Erldunda in order to get to the Luritja Road to Kings Canyon. You can take Ernest Giles Road, it is about 60 kms south along the Stuart highway from the
Rainbow Valley road. It can be a little corrugated and has a couple of sandy patches, but we drove this road towing our 2.6 Tonne Off Road Caravan a few years ago.
The road out to
Chambers Pillar from Maryvale Station is reasonable. There is one jump up that can be quite challenging, particularly towing a caravan. We did it in 2016 towing our van, 76 Series Landcruiser, low range 2nd gear got us over each way. Make sure you have everything securely packed in the van, as it will “
rock and roll” on the jump up. There are also some sand dunes as you get closer to the Pillar.
If you get yourself a Hema Road & 4WD Atlas, it has these roads clearly marked. It is not cheap, but we’ll worth the money. It is particularly useful when planning road trips, as it also has
camp grounds, rest stops and
point of interest marked as
925393
