Article Comment: ExplorOz Traveller
New App user here. Having trouble purchasing and down loading offline map packs but working through that slowly. Just purchased the pack via links from this website so hopefully that will generate licenses to use in app??
Also can not find app setting for "course up" instead of "North Up" in app settings?
Reply By: Member - cruza25 - Friday, Nov 15, 2019 at 13:23
Tap the icon just above the zoom+_ at the lower left to centre map up track up etc.
Have a look at the help page It is well written
Hope you get the licence sorted. You need to log on in the app then down load all the maps
Mike
AnswerID: 628675
Reply By: David P40 - Friday, Nov 15, 2019 at 17:29
Thanks.
Got the maps sorted now and will have a look out for the Track Up icon next time in the app.????
AnswerID: 628680
Follow Up By: Frank P (NSW) - Friday, Nov 15, 2019 at 19:28
At the bottom left above the + and - signs with a number in between, there is a thing like a gunsight. It's a toggle. Tap once and you're on north up. Tap again and it's course up. Tap again and moving map is off.
It may already be off (white), but the toggling remains the same.
FollowupID: 903142
Reply By: TrevorDavid - Friday, Nov 15, 2019 at 20:04
David
Different name but I think this is what you looking for.
TrevorDavid
dontyajustluvit
AnswerID: 628681
