Ctek D250s error on solar
Submitted: Saturday, Sep 28, 2019 at 19:12
Seacay
I seem to have a problem with my rooftop solar panel. The ctek works fine whilst driving and also when I plug in my mobile solar panel but shortly after I connect the rooftop solar the charger gives an error code.
Any clues as to what is going on?
Thanks in advance. Ken
Reply By: IvanTheTerrible - Saturday, Sep 28, 2019 at 19:28
What error code?
627906
Reply By: RMD - Saturday, Sep 28, 2019 at 20:11
Ken
Is the panel a new panel? Does it have an open circuit voltage more than the ctek can tolerate? Is the polarity correct from panel to Ctek solar input? Are you connecting both panels at the same time? If so, maybe the total solar input wattage is greater than the ctek max input wattage?
627907
Reply By: Seacay - Saturday, Sep 28, 2019 at 21:11
The error code indicated is - explanation : high temperature detected at either unit or service battery. The recommended fix - relocate unit or service battery.
The system has been running fine for 3 years and still has no problem with either car charging or auxiliary panel charging or both. Only when the rooftop panel is connected. Can the panel develop at fault that could cause this?
Ken
627909
Follow Up By: IvanTheTerrible - Saturday, Sep 28, 2019 at 21:20
If you have the temp sender hooked up to the service battery, try disconnecting it briefly to see if the fault disappears. Monitor the battery temp with your hand while you do this just to be safe
902156
Follow Up By: Seacay - Sunday, Sep 29, 2019 at 13:09
Today I removed the temp sensor of the battery and reconnected the rooftop solar and within a minute the display went from normal input to error.
I once again connected car and auxillary and it works fine. Driving me crazy.
902166
Reply By: CSeaJay - Saturday, Sep 28, 2019 at 22:55
Common problem, do a search on the
forum, from memory it is to do with insufficient solar input. Appears the ctek has a minimum inputbthat is much higher than other controllers.
Pita
627911
Follow Up By: RMD - Sunday, Sep 29, 2019 at 09:03
CSeaJay
If that is the problem, then if the panel is the one which has been used successfully in the past, it would point to it being a problem with cable or connections or high resistance not passing sufficient current / voltage under load to the Ctek.
902163
Reply By: Gbc.. - Monday, Sep 30, 2019 at 08:39
Considering it works perfectly with other panels, Id say it is an issue with your rooftop panels and there is nothing wrong with the ctek.
Have you checked the open circuit voltage of the rooftop panels? They may have simply failed - it happens.
627928
Follow Up By: Seacay - Monday, Sep 30, 2019 at 12:53
I don't have the specs. for the panel. Just checked open circuit value @ 21.2v
902181
Follow Up By: RMD - Monday, Sep 30, 2019 at 15:16
Therefore, at the end of the wires which go to the dc unit, you should have approximately the same open circuit voltage, and if you place a multimeter on AMPS setting, providing the panel isn't more than 10 amps Pmax current, directly across the terminals of the solar wire, the full ampere delivery of the solar panel to the plug or wires at the DC unit should be a reasonable amount. Never is it what the panel says though.
That way, you know panel voltage is present at the dc unit and amps available for use too. If OK, then the DC unit becomes in question. First things first.
902185
Reply By: Seacay - Thursday, Oct 03, 2019 at 20:59
I would like to thank you all for your efforts, much appreciated. After many disconnects and reconnectons of the various pieces it seems to have come good, no error light anymore. The battery seems to be charging correctly.
Thanks again
627981
