Sunday, Sep 29, 2019 at 16:09
Re the "not storing batteries on concrete" - a very sensible move in the day when batteries had wooden separators and battery cases were made from hard rubber that was slightly porous.
Storing these batteries on concrete was a no-no, as the porosity of the hard rubber case led to slow discharge.
Fast forward to the late 1960's and early 1970's, and battery cases are now being made from polypropylene - as they still are today.
As a result, the belief that batteries self-discharge on concrete, is no longer a valid issue, as it was, when battery cases were made from hard rubber.
In fact, there is at least one good reason to store your batteries on concrete, particularly if you reside in a high temperature region.
Because heat is the killer of batteries, storing batteries on cool concrete will more than likely improve their lifespan - provided you keep them charged, of course.
If you live and work in a hot climate, your battery has only 2/3rds the lifespan of a battery being used in a cold climate - so anything you can do to reduce your battery temperature will have a life-lengthening effect on it.
Cheers, Ron.
902169
