Thursday, Aug 15, 2019 at 13:03
I got 4 years and 4 months out of the OEM battery in my diesel 2013 Hilux.
It was still starting O.K., every day, all day long - but if I allowed any current draw (even relatively low current draw) to happen over a couple of hours - such as leaving the door open, and the interior light on - the battery would refuse to crank the Hilux at normal speed. It just wouldn't start it.
The final kick came the morning in early July 2017, right as I was loading up to drive to
Broome from
Perth.
I left the drivers door open for an hour, while I loaded up, and the Hilux wouldn't start.
I went and purchased a new battery, and put the old one aside, and went to
Broome for my Winter break.
When I came back from
Broome, I set the old battery up on my 4 amp trickle charger, with my Infinitum battery desulfator. I left it on charge for a couple of days.
When I'd finished charging it, I installed the battery in my Toyota 4 cyl diesel forklift.
It worked just fine! - and it's still working just fine, a full 2 years later! It will still start the forklift, no problem, on cold mornings.
This battery is a bog-standard lead acid battery with screw-on tops. Just goes to show that sulfation is always major problem with L-A batteries and it can often be reversed with a desulfator.
Cheers, Ron.
901250
