Saturday, Mar 30, 2019 at 09:25
Allan B
It matters not as to where the manual switch gets its power whilst it is in the OFF position as the VSR type battery isolator will stay ON until BOTH batteries have dropped to the VSR drop out voltage.
If you doubt this statement then try using a VSR when the Auxiliary battery is a Lithium battery, as these batteries maintain good voltage until they are almost completely flat. Whilst it is not recommended that a VSR be used in conjunction with Lithium it can be done provided that there is an ignition activated cut out fitted to the sensing wire of the VSR, so that the sensor is only active when the ignition is in the ON position.
By their very nature all VSR's sense the voltage on the start battery side, and whilst the VSR is in the on position then the voltage on both sides of it are equal (allowing for some small variation due to the resistance across the contacts).
As far as wanting to combine both batteries for winching purposes I would not entertain this idea. When winching you should always, as far as practicable, have the engine running so as to provide the best available power supply (batteries plus alternator), and as such then the VSR will be in the CLOSED position., and as such both batteries are then employed for the winching process.
Should it not be desirable for some reason to have the engine running then it is preferable to use the Auxiliary battery for winching, as this then allows for the engine to be started from its starting battery instead of having BOTH batteries flat, if the engine is in a suitable condition to be restarted.
I will always fit my vehicles up so that the starting battery is used just for that, starting the engine, and any additional batteries are used for all other purposes with the ABILITY to be used as an emergency starting power supply.
Athol
898193
