Friday, Jun 30, 2017 at 09:53
"The South African Rangers are not imported into Australia."
That may be true - but the Ford/PSA Duratorq 3.2L engine is a "global engine" and it is sold in a large number of countries with only slight modifications, and fitted to quite a range of vehicle models.
I consider South African operating conditions to be very similar to Australia, unlike North American, British and European conditions, where ambient temperatures, road conditions and hazards encountered are substantially different.
Manufacturers are not concerned with 100% engine reliability and infallibility.
I've been informed from a reliable source within manufacturing that they aim for a reasonably low failure figure, that is "acceptable" to them.
To an owner, engine failure is a disaster. To a manufacturer, it's merely an opportunity to sell more parts and components, and improve their bottom line.
They don't really care if 1 in 2000 engines fails due to a manufacturing fault or some other reason related to poor design. That kind of numbers doesn't affect sales in any serious manner.
The engine problems we have today, with current engines, are related to increasing complexity and a "low tolerance" style of construction.
A "low tolerance" engine has little tolerance to going out of spec, or coping with a component failure, or tolerating some kind of owner ignorance.
The old engines from pre-emission control days were "high tolerance" engines, they could cope with wear in components, adverse operating conditions, owner/driver/operator abuse and ignorance - and they would keep running.
Today, we have engines that run on very tight tolerances, they have little margin for wear, so construction materials have been improved to try and lower wear.
However, if an adverse event happens (hose failure, dirt ingestion, overheating, etc), then the engine fails rapidly, and in a big way.
Todays fuel injectors are a typical "low tolerance" item, they run at half the clearance of the older injectors, as
well as incredible pressures, with the resulting low tolerance to dirt and water.
The Duratorq design has a number of "European" features that I consider undesirable. A water-cooled EGR valve that is prone to failure on an unacceptably high basis. This device is complex in its construction and is obviously prone to manufacturing faults that only appear after some use. An EGR cooler failure results in a seriously-damaged engine.
The coolant hose abrasion problem, which was a simple, poor assembly design, appears to have been fixed with a recall. There may be a number of engines out there that missed the recall, this is common, due to the poor Ford response as regards carrying out recalls - and also due to owners doing their own maintenance.
The Duratorq engine utilises bearing shells with no locating tang - unlike earlier designs. The tang was originally a standard design in all bearing shells that ensured proper location of the bearing shells and to ensure they did not spin inside the conrod or block.
The Duratorq bearing shells have no tang and are merely clamped in position by the tightness of the main bearing cap, or the conrod bearing cap.
As a result, if you are lax with maintenance and do not change oil regularly, or use an incorrect type of oil, the bearing shells are likely to "grab" and spin in their housings. Once again, a low tolerance to abuse. The old engines would run happily with oil like tar.
You are correct, the number of engine failures with the Duratorq engine is still relatively low, as compared to the number of vehicles in use.
However, they are a complex engine with a need for particular care in operation, frequent servicing and regular inspection to pick up potential developing problems, and owner knowledge of the situations and conditions that they will not tolerate.
Here's a list of Duratorq 3.2L recalls and known faults. I don't believe this is an entirely complete list, and there are other, known faults that owners need to be on the alert for.
Ford Ranger (2011-on) recalls and Ford-recognised faults
882443
