Monday, Jun 19, 2017 at 14:25
Peter you can't fit any 16" tyres on a 200 period.
17" tyres were hard to source in the bush about 7 - 8 years ago. Though I guess either 16, or 17" Landcrusier tyres would have been easier to source than tyres for less common 4wds or trucks even then. 17"s are commonly available in Mud or AT these days with tons of choice.
I would have thought that 17" Landcrusier profile tyres would be much more likely to be in stock than for less common vehicles. If I was a tyre dealer I would stock tyres suitable for Landcrusier 100, 200, 70, Prado, Patrol. The rest can be dammed and wait. It's not just the wheel size, it's the profile that matters too.
If it's lots of sidewall your after, the standard 100 sidewall height is only 6mm different to a 200's standard sidewall height. If that is still a concern a 200 with 285 70 17's will have 7mm more than a 100 and still have more power. Or 275 70 17 will be the same.
If you don't mind me asking, why do you see no 16" as such a big issue? I've spent many trips in deserts, most less travelled than the Simpson and have never wished I had 16".
Well not in the last 8 or so years anyway.
Other issues that help in a simpson crossing are better traction control, a Torsen center diff and the ace in the hole CRAWL which will dig you out of a sand hole.
Tell me a 100 is better than this. Go to about 5:20 for when it starts to work. Look mum no hands.
or this Go to about 3:40 TURN THE SOUND OFF..
882042
