Renmark to Yunta
Submitted: Tuesday, Jun 06, 2017 at 20:08
ThreadID: 135032 Views:3446 Replies:2 FollowUps:5
Can anybody advise what condition this section is in? 4wd, 2wd, rough or easy.
Reply By: Frank P (NSW) - Tuesday, Jun 06, 2017 at 20:34
As far as I am aware it's all sealed and flat unless you look for by-ways which will still be flat but obviously subject to weather.
AnswerID: 611728
Follow Up By: IvanTheTerrible - Tuesday, Jun 06, 2017 at 20:43
Direct through Danggal Reserve not around through Morgan
FollowupID: 881773
Reply By: Member - Stephen L (Clare SA) - Tuesday, Jun 06, 2017 at 20:42
Hi Ivan
With a question like that, I would presume that you want to head up through Danggali and then further North?
If so the roads in that area are well formed major station roads that are used on a daily basis.
Like all dirt roads, it will come down to when it last rained, which out that way has been some time ago.
There will be a good combination of road surfaces, from corrugations, sand to high speed, good quality dirt.
Just take your time and drive to the conditions, as there is some great country out there east of Burra.
Smile like a Crocodile
AnswerID: 611729
Follow Up By: IvanTheTerrible - Tuesday, Jun 06, 2017 at 20:46
Thats what I needed. I'm OK with it but a mate wants to tack a soft roader up there
FollowupID: 881774
Follow Up By: Member - Stephen L (Clare SA) - Tuesday, Jun 06, 2017 at 21:01
Hi Ivan,
Just take your time and he will have no problems at all providing it is dry.
We have been out there many times and you can drive a standard Ford or Holden Ute, with no problems at all.
I presume you know where to head out from?
If not, head out on Ral Ral Avenue in Renmark and just then follow the signs to Wentworth. About 40 minutes out of Renmark, turn left onto the road signposted Danggali.
FollowupID: 881776
Follow Up By: IvanTheTerrible - Tuesday, Jun 06, 2017 at 21:41
We'll actually be coming from Wentworth.
FollowupID: 881780
Follow Up By: Member - Stephen L (Clare SA) - Tuesday, Jun 06, 2017 at 23:40
Hi Ivan
That will be no problems at all.
Around 6 kilomtres after crossing into SA after the SA / NSWBorder crossing, the Danggali turn off will be on your right hand side.
Seeing you are in the neighbourhood as such, it is well worth the very small detour to visit Todd's Oblisk and the old Scab Inspectors Hut.
FollowupID: 881782
