Appending track files
Submitted: Sunday, Jun 04, 2017 at 14:39
ThreadID: 135019 Views:2453 Replies:2 FollowUps:5
Hello Forumites, could anyone give me a quick rundown on how to append daily track files into 1 complete track. I have tried but can't seem to get it right and Duncan who usually does this for me is away for the month.
Regards Sludgie
Reply By: The Explorer - Sunday, Jun 04, 2017 at 15:32
Using what format files in what program? Could assume OziExplorer plt files using PC version or is it gpx.files, Then there is Garmin - Mapsource, Basecamp, Memory Map, Trackranger?????????.
AnswerID: 611680
Follow Up By: Sludgie W.A - Sunday, Jun 04, 2017 at 15:43
I have Oziexplorer android with track files plt. that I need to append on Oziexplorer PC and then put back on the android system.
Regards Sludgie
FollowupID: 881717
Follow Up By: The Explorer - Sunday, Jun 04, 2017 at 15:46
easy peasy - see below...
FollowupID: 881718
Reply By: The Explorer - Sunday, Jun 04, 2017 at 15:40
If its OziExplorer (PC version) your are takling about and plt format files - load first track and then append tracks using LOAD->APPEND TRACK FROM FILE. Add as many as you like then save the track file.
AnswerID: 611681
Follow Up By: Sludgie W.A - Sunday, Jun 04, 2017 at 16:29
Thanks Greg, I was aware of the screen shot that you put up. My problem is when I append how do I rename the file, do I make a new file name on the appended list next to the open box and then open a plt or do I make a new file name elsewhere?.
I just have a complete mental blank at present (10 years or so according to the wife) and logic has flown out the window.
Thankyou Terry
FollowupID: 881719
Follow Up By: The Explorer - Monday, Jun 05, 2017 at 10:41
Hello again - sorry for delayed reply, been busy.
Ok - after you append all the tracks you want together then click Save -> Save Track to File (Track 1 only). You will then be prompted to save the combined file with a name of your choice.
FollowupID: 881736
Follow Up By: Sludgie W.A - Monday, Jun 05, 2017 at 12:04
Thanks Greg, easy when you know how.
Regards Terry
FollowupID: 881738
