Dual Fuel Tanks
Submitted: Saturday, Jun 03, 2017 at 07:08
ThreadID: 135005 Views:2938 Replies:3 FollowUps:3
Has anybody put big fuel tanks on their D-MAX?
How big did you go, who did it and are you happier?
Comments any please?
Thank you
Reply By: Kazza055 - Saturday, Jun 03, 2017 at 07:18
I had the 137L Long Range Tank supplied with my new D-Max back in 2014. It was supplied and fitted by TJM as part of the initial purchase.
This give me a range of 1,000+L/100 normal highway and I have had 650L/100 towing our 2500kg van. I normally work on a safe range of 550K when towing which is a long way to drive without a stop.
Be aware that the fuel gauge and distance to empty do not move until you have used about 40 litres but then they are spot on.
AnswerID: 611632
Follow Up By: RMD - Saturday, Jun 03, 2017 at 09:39
1000L/100 is 10 litres for ONE kilometre, or 1 litre per 100 metres.
Do you mean 1000+km range?
FollowupID: 881677
Follow Up By: Member - Rod N (QLD) - Saturday, Jun 03, 2017 at 11:51
I did the same. Yes 1000+ km range.
FollowupID: 881682
Follow Up By: Kazza055 - Saturday, Jun 03, 2017 at 14:21
Oops, yer lets make that 1,000k and 650k.
Obviously I was still half asleep ;=(
FollowupID: 881686
Reply By: Idler Chris - Saturday, Jun 03, 2017 at 09:06
I also had a long range tank fitted to my D-Max when purchased in 2016. I do a lot of remote outback touring so strength was a very importaqnt factor. I have an ARB plastic tank about 134 litres and I could not be happier. Extreamly strong and lighter than the original tank.I have a tray configuration and it will take a hi-flow pump at full bore right up to full, it may, or it may not be the same for a tub configuration.
Chris
AnswerID: 611633
Reply By: Tony F8 - Saturday, Jun 03, 2017 at 13:05
Have a look at ENMACH industries web page, they have a whole range of tanks, and if there is not one to suit, they will build you one, very well, priced and you cannot fault the service
AnswerID: 611639
