Hand cut tunnel
Submitted: Saturday, May 20, 2017 at 13:57
ThreadID: 134905 Views:3693 Replies:3 FollowUps:3
Does anybody know how high the clearance is on the shortest hand cut tunnel in Australia is? & does the road have load limit? its on the road from Mittagong NSW to Wombeyan caves the tight, windy dirt etc one
Reply By: Hoyks - Saturday, May 20, 2017 at 15:00
You mean this one?
Its a good size, not sure of the clearance though.
http://4x4earth.com/forum/index.php?threads/wombeyan-to-jenolan-18-09.37181/
AnswerID: 611244
Reply By: duck - Saturday, May 20, 2017 at 16:09
That's the one
I've looked up he RMS/rta web site & several others but none have the hight
AnswerID: 611246
Follow Up By: Member - Tony H (touring oz) - Saturday, May 20, 2017 at 17:12
Maybe a quick phone call to the local council???
FollowupID: 881265
Follow Up By: Dean K3 - Saturday, May 20, 2017 at 19:51
If its to low for commerical vehicles minimum of 4.5 m it would need to be sign posted accordingly.
Know one bridge in Perth WA always catches out some truck drivers posted at 3.5 but many try to fit under at 3.8 or higher
and for what its worth WA only has one tunnel carved by hand and its no longer used - old railway line between midland and hovea station before Avon valley route was implemented
FollowupID: 881271
Reply By: Member - Scott M (NSW) - Sunday, May 21, 2017 at 01:26
Always this one Guy Fawkes NP
AnswerID: 611257
Follow Up By: Ozhumvee - Sunday, May 21, 2017 at 06:51
The one above will take a rigid truck with a stock crate on it, there is also a large puddle in the middle of it in wet weather as the bottom dips down.
I've also seen largish trucks and motorhomes go through the one on the Wombeyan caves road so caravans have no problems
FollowupID: 881285
