Sunday, Feb 19, 2017 at 19:21
I did write typical, the same applies to most if not all alternators.
Modern alternators have temperature compensation, this can reduce alternator output current under overload conditions but this is not what its intended for and it shouldn't be replied upon for this purpose.
I have not seen a typical alternator regulator that has overload current protection, in fact all alternators I'm familiar with do not produce their maximum output until the regulator has dropped out?
Last time I spoke to Bosch regarding their alternators ratings they advised to de-rating to at least 80% for continuous operation at high loads, their common alternators have no internal overload protection. Denso advised to de-rate to 70%, again no internal protection against overload.
A quick
check of the net shows statements that many regulators have over current protection but I have yet to see one that actually does, I would be interested to see the alternator your basing assertions on?
Over current protection in an alternator is pointless, the basic design of the alternator limits its maximum current to safe levels. This does not mean you can't overload the alternator though, an overload manifest itself as you wrote by a rise in temperature, if the alternator can't shed its heat load it could overheat and be damaged, this could be as a result of high ambient heat, the alternator being required to supply high outputs for long periods of times or combinations of thereof.
With regards to Land Cruisers, the only LC I'm aware of that uses a ECU controlled alternator is the new Prado 2.8Ltr, the alternator in the new Prado appears to be a LIN type, however Toyota appear to be either not using it or have coded the engine management system to emulate the previous models temperature controlled alternator as the outputs of both are nearly identical under the same conditions. There is no current sensor or smart charge functions yet.
Regarding the negative battery cable, modern ECU controlled charging systems generally use a hall effect device or other sensor to monitor the current flowing in the wire, hall effect devices detect the magnetic field generated by current flowing through the wire, other sensors such as terminal mounted units have shunts in them, if you can change the size of the cable it will not affect the current reading of these devices.
878430
