Saving Tracks
Submitted: Saturday, Nov 14, 2015 at 18:31
ThreadID: 130891 Views:1897 Replies:3 FollowUps:3
I just went into EoTrackMe and saved my current track which was over 4000 K's long. However it is not in My Treks and no longer in EoTrackMe current track. Where has this track gone? Have I done something wrong or is it the system hiccuping?
Reply By: baznpud (tassie) - Saturday, Nov 14, 2015 at 19:33
Hi Chris,
Pud and i just completed a 700 odd trip in Tassie, and i saved it to MY TRACKS, well so i thought, it went to the Tassie State tracks, and i can't work out how to retrieve it, will wait and see what happens.
Cheers.
baz
ps. hope the new bus is preforming well for you.
AnswerID: 592721
Follow Up By: Idler Chris - Saturday, Nov 14, 2015 at 22:48
Thanks Baz. My track was before and after the Gathering so I looked under NT and sure enough it was there as Route Id 5443. It does not show in my treks I will send a message to D & M.
Have not got the new bus yet, but it is on order an Isuzu D-Max. I wanted a cab chassis and the Isuzu is the only one made by a truck company. I will be putting a Gecko camper on it, also on order. Cheers Chris
FollowupID: 860892
Reply By: Member - Trevor_H - Sunday, Nov 15, 2015 at 21:31
Under "User Treks":
https://www.exploroz.com/UserTreks/5443/NT+Saved_Tracking_Log.aspx
Had the same problem, haven't worked out how to change the title on mine yet.
AnswerID: 592763
Follow Up By: Member - Trevor_H - Monday, Nov 16, 2015 at 22:53
Now able to change the title....Thanks David.
FollowupID: 860967
Reply By: ExplorOz - David & Michelle - Monday, Nov 16, 2015 at 14:58
Chris,
I had half finished an update to the user management of User treks and this caused the missing item. You should now be able to see it in your My Treks listing and if you open the User Trek there should be an Edit User Trek button on the page. It should all be good to go, let me know if you experience any problems.
David
AnswerID: 592778
Follow Up By: Idler Chris - Monday, Nov 16, 2015 at 15:07
Thanks David all good now.
FollowupID: 860956
