Caravan air conditioning
I am placing an order for a new caravan and need advice as what is the brand of air conditioner to have installed, don't need reverse cycle as having diesel heating. Any advice greatly appreciated.
Reply By: Member - Tony H (touring oz) - Saturday, Dec 01, 2012 at 11:01
Don't discount reverse cycle..... what if you are in a CP & want heat the van... use their power rather than than your diesel.... also think you will have a better selection with reverse cycle as far as brands go. Can't advise re current selection ..... sorry
AnswerID: 499570
Follow Up By: Hunter Gatherer - Saturday, Dec 01, 2012 at 11:04
Thanks Tony, hadn't thought of that, so will get R/C, now to decide on what brand is best ??????
FollowupID: 775574
Follow Up By: Member - Tony H (touring oz) - Saturday, Dec 01, 2012 at 19:21
Interested to know what 'make' of van you are going to be ordering??????
FollowupID: 775604
Follow Up By: Hunter Gatherer - Sunday, Dec 02, 2012 at 01:51
Tony, I will be ordering a New Age, Big Red 22'6" custom built with every thing available.
FollowupID: 775620
Reply By: landseka - Saturday, Dec 01, 2012 at 11:20
My advice is ...do not get a rooftop Dometic style. They are next to useless as a heater, not a lot better on cooling, noisy, heavy, power hungry if using on a genny while freedom camping.
Most folk now are going to household split systems to address all the above problems for maybe 1/3rd the price. If mounted well there are no issues with them being 'mobile' as opposed to a fixed installation.
The only drawback is the sometimes difficulty finding the suitable spot to mount the head unit. If no overhead space then in front of the bed at floor level works.
Cheers Neil
AnswerID: 499571
Follow Up By: Member - bungarra (WA) - Saturday, Dec 01, 2012 at 12:14
I second those comments on the Dometic....but we still use it for cooling..genny can struggle a bit on a really hot day
for heating we have the diesel heater when out bush (bit noisy for the neighbours when in a c/van park....dont use it not fair on the others around you)......but very quiet and hardly noticiable from the inside of the 'van when parked on our own
also carry a small electric heater/blower for space heating when in a park...usually a lot quieter and just as effecient than the roof top
VKS 1341
FollowupID: 775578
Reply By: Geoff K4 - Saturday, Dec 01, 2012 at 11:48
Try for a newer type such as inverter as the fixed speed compressers do make a lot of noise when they cycle off & on. May keep you awake at night. The Inverter type don't cycle, they have variable speed compressers & automatically vary according to your set temperature point. Plus cheaper to run if cost is an issue.
Geoff
AnswerID: 499572
Reply By: graham B9 - Saturday, Dec 01, 2012 at 12:29
Forget a roof top all together and go for a split system like in a normal house. Humpback Caravans in Port Wakefield have been fitting them for some time and they work fantastic. You can have the compressor ( normally outside part in a house) fitted to the rear outside of the caravan or mounted inside with access panel that opens when running. Not trouble with dust / rain and generaly weather. Nor travel vibrations either.
The last longer and cost less to buy. Lower running costs and are much more silent. You can also have an outlet in the bed room and another in the lounge room.
AnswerID: 499578
Follow Up By: Hunter Gatherer - Saturday, Dec 01, 2012 at 13:18
Graham and everyone else thank you for taking the time to reply with helpful advice, think I will just get a fan !!!!!!!! LOL.
FollowupID: 775580
Follow Up By: GEMAC Solar and Power - Monday, Dec 03, 2012 at 10:10
Hi again
If you are thinking of installing a Domestic AC Wall Split I would be looking very seriously at the manufacturers warranty.
I very much doubt that they will warrant any instal to a van or mobile installation.
These units are not manufactured to take into account the vibration that is transmitted during travel.
And yes they are not operational during that time but there is still vibration
Geoff
FollowupID: 775682
Reply By: Jeff P - Saturday, Dec 01, 2012 at 17:17
Hi I also have the same problem regardless of what poeple say the current RV airconditioners are junk period and I cant understand why people just accept that! a household split systerm is far superior to the RV air con's my new van will be 24 feet so you can see the problem I have ,every van manufacturer only wants to fit the AC or dometic, it took me ages to convince them to go to instant gas hot ! I would not accept the "norm" in hot water and Iam working on finding a solution to the air con problem as well If I can find a way to fit an inverter split this is the way to go and maybe some smart caravan makers will wake up to this as well
Jeff
AnswerID: 499598
Follow Up By: graham B9 - Sunday, Dec 02, 2012 at 08:10
Jeff shoot me an email to this address and I will send back pictures of our new inverter split systems that we have been fitting to caravans.
carlsp1000@gmail.com
FollowupID: 775632
Reply By: John E - Saturday, Dec 01, 2012 at 20:06
I have a Dometic in our van , and i have also been in a van with the split system , and there is no contest , the split wins hands down , we will be going with that when /if we go to another van , have a look at'aussie by design' at port wakefield , sa, there is usually a van ready to go to its very proud new owner , that you could maybe have a look at . cheers lyn
AnswerID: 499609
Reply By: Member - John and Lynne - Sunday, Dec 02, 2012 at 14:18
Our roof top Dometic is useless at heating and cooling and it vibrates so much the van roof shakes. We took it to Dometic under warranty, assuming it had major problems, and they checked it out and said there was nothing wrong - that was as good as they get! We will never get another one. Friends just installed a couple of 12 volt fans and they are very happy with no aircon at all. We will do the same. We prefer sleeping with open windows and sitting outside anyway rather than being cooped inside with a noisy machine. Running an aircon with a generator all night in most places is likely to get you evicted and will certainly make you very unpopular and you can't always find camp spots where you are entirely alone! John and Lynne
AnswerID: 499668
Follow Up By: GEMAC Solar and Power - Monday, Dec 03, 2012 at 09:42
We did away with the AC fitting on our van.
Had the wiring installed but that's all.
If you are going to be anywhere other than a van park you will need a very long big lead and a genny to run it. And if you are anywhere at night having a genny running to keep cool is not what the neighbours want to hear.
Agree with a diesel heater but a fan is just as good an AC Unit.
get one of those new misting fans and it will run on a small invertor if required and no noise.
Geoff
FollowupID: 775679
Reply By: GEMAC Solar and Power - Monday, Dec 03, 2012 at 09:43
Ahhh John and Lynne
A couple after our own hearts
Fresh air as it is intended and NO NOISE
AnswerID: 499711
