Comment: Snake Bite Treatment
The snake bite first aid procedures in this article are not correct. We have produced Snake Bite First Aid Instructions based on advice from leading CLINICAL Toxinologist Prof. Julian White and they are available from www.workingwithwildlife.com.au under our references section.
Bandaging MUST be started at the extremity of the limb to reduce new lymphatic flow generation and continued as far up the limb as possible. An elasticized bandage is not recommended - use a Heavy Weight CREPE Bandage 10cm wide by 2.3m long. Our advice is to keep 3 of these in a handy first aid kit or get on of ours which is specifically designed for snake bite treatment.
There is so much wrong information about Snake Bite First Aid being publicized, no wonder the public get confused.
