leaf springs reset factory or aftermarket
Submitted: Sunday, Aug 28, 2011 at 22:16
ThreadID: 88744 Views:9187 Replies:6 FollowUps:3
Hi all, looking for peoples preference towards having factory leaf springs retentioned or going for aftermarket. It is for a 2007 d40 navara dual cab with a tray body opposed to the well body, also extended an extra 300 mm. It is fitted with a 150 ltr long range tank and is only used for long distance highway and the odd trailer. No real off road requirements with this vehicle, I have a 100 series for that. dont want to spend too much, the rear end is sagging a bit at the moment and needs a 50mm lift straight away, I dont know what the standard ride height should be, so that is where the retention is appealing can be set to where I want them.
Reply By: Member - Bucky - Monday, Aug 29, 2011 at 05:50
Poly air bags
AnswerID: 463767
Follow Up By: get outmore - Monday, Aug 29, 2011 at 13:23
definitly NOT places load where there shouldnt be any and moder chasis wont take it
guy on a local forum has just bent his mazda in half using them
FollowupID: 737655
Reply By: AlbyNSW - Monday, Aug 29, 2011 at 11:00
I have a similar configeration in a Hilux. I originally had my springs reset and another leaf added which worked well but found the ride a bit harsh when driving unladen.
I changed over to Ultimate Suspensions rear leaves at Minto (Sydney) and found them to be more comfortable.
AnswerID: 463783
Follow Up By: Member - iijmartin - Monday, Aug 29, 2011 at 11:42
Hi hotfishez,
I have 2010 D40 towing heavy van. I am having OME suspension installed tomorrow. I am prepared to wear the harsher ride without the van on. Perhaps I will throw into the tub a few bags of wheat if I am driving without the van on the back. However, i am looking forward to a better towing ride plus the extra clearance for the occasional off road drive into the Flinders next month.
Air bags seem the go..but I am nervous with the stories of cracked chassis carrying heavy loads/heavy ball weights.
I did look at the Ironman Load Plus Helper springs.
Regards,
Ian
FollowupID: 737648
Reply By: Fatso - Monday, Aug 29, 2011 at 18:51
I only this week did the rounds looking at options for my Hilux cab chassis rears.
I am not too keen on after market leaf suspension. They all seam pretty rigid & no consideration is taken for my particular uses.
What I have is an custom aluminium tray with a 120 l water tank & second battery mounted. So it is pretty light if the water tank is empty.
I want to put a large lockable box/canopy on the back that will carry all our gear including push-bikes & maybe once in a blue moon a dinghy. But when I get home from camping or touring I am going to be taking that off. We are also in the market for caravan up to 2000 kg. That's a fairly wide variety of loads.
So after market leaf springs are going to be around $700 + fitting for Kings Springs with very limited options for ride height & no allowances taken for changing loads.
Air bags are around $1000 for Firestone fitted.
The local spring maker can set the springs up so that when the box is on & loaded it will ride on the mains & the helpers & when the box is off it will ride on the mains only. This can be set up to any desirable height.
I know he will get it right as he has done springs for me before & has many other satisfied customers in Cairns. He has been making & setting springs for near on 50 years.
This is going to cost me $374 drive away with new bushes.
I would trust his spring work & recommendations a lot more than generic built springs & the word of a salesman that was working at BCF or KFC last week that know nothing except what the brochure says.
I am not so fussed on air bags either. That is changing the whole design of the suspension.
I recommend you go & talk to a good spring maker or you might find yourself driving around with a couple of sandbags or bails of hay in the back.
AnswerID: 463811
Reply By: Paul and Mel - Monday, Aug 29, 2011 at 19:31
many years ago i had leaf springs reset and leaf added but they sagged horribly, more on one side but they both did it. i will never do that again, buy a new aftermarket spring as you will be much happier with it.
AnswerID: 463813
Follow Up By: Dave... Adelaide (SA - Tuesday, Aug 30, 2011 at 00:11
I agree with Paul, l had the rear springs on my patrol ute reset a couple of years ago before going to Cape York, by the time we got back to Adelaide the springs were back to where they were before l had them reset.....If ever l was to need springs again l would much rather pay a little extra for new ones..
Cheers.......Borgy
FollowupID: 737701
Reply By: Bueff - Tuesday, Aug 30, 2011 at 15:00
Hi Mate,
I had to fit new suspension in my Hilux about 6 month ago, I went for the aftermarket springs and RAW shocks, also had some firestone airbags fitted. Honestly they are a treat, I carry a heavy lift off toolbox with all my building tools in it, pump them up for heavier loads, let them down when empty. All you need is a 12v compressor. Just make sure you don't go overboard with loading up your truck, its easy done with the bellows in the back.
good luck
Jens
AnswerID: 463857
Reply By: workhorse - Tuesday, Aug 30, 2011 at 19:39
I have a Ford Courier single cab ute used empty 50% on farm and dirt roads, 25% overloaded with whatever is needed to be carried and 25% touring/camping. I have had the Equaliser from CVSS (SAX Suspension) fitted to my rear leaf set up. Basically it is a helper spring and the change in the vehicle has been very successful. Empty on the soft setting the ride is no harsher, on the hard setting loaded the back sits nicely, no squatting and wallowing. I fitted them myself in 30 min. I currently run Rancho 9000s on the rear but these are due to be replaced.
I have no negative comments at all.
AnswerID: 463892
