Major System Update
Submitted: Thursday, Jan 20, 2011 at 12:31
ThreadID: 83767 Views:3378 Replies:2 FollowUps:2
Hi everyone,
Today I am planning to install a major update to the user database. This update effects all visitors, members and customers. On the plus side the update means that all logins are handled by your email address and password. So there is no need to remember your member numbers to login to the system. Just entering your email and password is all that is needed and the system will determine you level.
I am hoping to automatically update your auto login cookies when you visit the site so you should not even have to login again after the update.
I do expect that there could be a few issues moving forward so please let me know if things are not working for you so that I can get the issues resolved. Of course one of the tasks we must do is update all our email templates and site tips to reflect the changes so if you get any of these emails and they say the wrong things please let us know as we may have missed something.
I am crossing my fingers that all goes to plan but I am a realist and in the past I have not had that many go without incident but let's hope I get this one right.
David
PS: I expect to be looking to install the updates in the next few hours, I have some more processes to update before I can start.
Reply By: MickL13 - Sunday, Jan 23, 2011 at 09:21
OK, so I'm an idiot, but I can't find the site address to log in. I think I've been all over the site and found HEAPS about joining and member benefits but cannot stumble over the log in page or icon. HELP!!!
AnswerID: 442772
Follow Up By: ExplorOz - David & Michelle - Sunday, Jan 23, 2011 at 12:43
Mick,
You must already be logged in as you have replied to this thread and forum usage requires that you are logged in.
PS I have not installed the updates yet the job has gotten bigger and will be done during the week.
DM
FollowupID: 714817
Reply By: wozzie (WA) - Tuesday, Jan 25, 2011 at 02:34
David,
Not sure if you have activated anything yet, but this is an error message I receive when trying to go to the members MyHome page from the link at the top right.
Hope this of some use to you.
Wozzie
Server Error in '/' Application.
Could not load type 'ITBeyond.Email' from assembly 'ExplorOz_Classes, Version=2.1.2.0, Culture=neutral, PublicKeyToken=null'.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.TypeLoadException: Could not load type 'ITBeyond.Email' from assembly 'ExplorOz_Classes, Version=2.1.2.0, Culture=neutral, PublicKeyToken=null'.
Source Error:
The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL:
1. Add a "Debug=true" directive at the top of the file that generated the error. Example:
or:
2) Add the following section to the configuration file of your application:
Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode.
Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario.
Stack Trace:
[TypeLoadException: Could not load type 'ITBeyond.Email' from assembly 'ExplorOz_Classes, Version=2.1.2.0, Culture=neutral, PublicKeyToken=null'.]
ITBeyond.Mapping.Place.setPlace(Boolean SystemUpdate) +0
ITBeyond.Mapping.Place.getPlacefromDataRow(DataRow DR) +1918
ITBeyond.Mapping.Place..ctor(DataRow PlaceDataRow) +188
ASP.members_default_aspx.getPlacesUpdatesSince() +415
ASP.members_default_aspx.Page_Load(Object sender, EventArgs e) +837
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Version Information: Microsoft .NET Framework Version:2.0.50727.3615; ASP.NET Version:2.0.50727.3618
Dreamin' agin
AnswerID: 442959
Follow Up By: Richard W (NSW) - Tuesday, Jan 25, 2011 at 07:03
David/Wozzie,
Same here.
FollowupID: 715016
