Sunday, Aug 29, 2010 at 19:30
WBS,
also consider removing the Redarc from the system if all the battery cables (+) and (-) are firmly connected.
Remove the two battery cables from the bolts on top of the Redarc and bolt cable lugs firmly together, be VERY careful that they are then tied away from any and all metals, then run the engine for a while and see if the fuse blows again, this will eliminate the Redarc as part of the cause.
BEFORE doing this, first measure the standing voltages of both batteries separately, then again when the battery lugs are bolted together.
Putting the batteries in parallel the voltages will equalize, the Cranking and Aux battery should be about the same voltage when measured individually, when paralleled will equalize between the voltage of the two batteries.
(eg, 12.60v and 12.70v when paralleled will be ~12.65v when using same capacity batteries, this will show you you have a faulty cell in either battery)
Maîneÿ . . .
699610
