Tyre Pressure Monitors - Which one (if any?)
Submitted: Thursday, Aug 19, 2010 at 16:58
ThreadID: 80816 Views:7736 Replies:10 FollowUps:11
I’m after feedback on tyre pressure monitors.
I have read various discussions over the years on the forum and the viewpoint I formed some time back is that the concept is great, but yet to be perfected as an after-market product.
On a recent trip ‘The Landy’ suffered a flat on the rear left, the tyre was quite hot and possibly not far from sidewall failure when detected. I guess this is where a monitor would be useful. And now that we have added a TVAN to the touring kit I am keen to revisit this topic.
What are others more recent experiences and which ones do you use?
Cheers, The Landy
Reply By: Mick O - Thursday, Aug 19, 2010 at 17:33
Cheers Landy,
I have had a few opinions over the years in respect to various tyres of TPM systems. For the serious traveller, I believe they are an invaluable asset. If it saves one expensive tyre from replacement, they have all but paid for themselves, still, I'm sure you don't need convincing.
I own both a set of Sensatyre (On both my Nissan and the new Ute) with internal sensors and a set of tyredogs with a valve mounted sensor that can be screwed off. Both are multi vehicle combinations. I have 8 sensors on the Sensatyre system to cover trailer, vehicle and two spares. I utilise two external receivers at the front and rear of the vehicle. The Tyredog is set for 6 tyres being vehicle and trailer with two receivers again.
I am a big fan of the internal mount sensors as they are largely protected from external damage. I had a bad time with the Sensatyre unit last year due to rough terrain. I must add that normal highway use wouldn't have these issues. I found this year that by utilising short valves on the rims and by using electrical tape around the caps, all sensors remained intact and operating.
For ease of use, I prefer the Sensatyre as they are easier to reprogram, particularly when on the move. ie Low pressure/temperature warning setting can be easily and quickly adjusted should your needs change, ie dropping tyre pressure to deal with sand or corrugations.
Obviously screw on sensors provide added ease of functionality for rotating to other wheels. My personal opinion is that the quality and functionality of the Sensatyre system is better. Certainly the robustness of the sensor system is excellent as well. I would also praise the level of customer service from the distributers at Hannibal in QLD who will readily go through any issues over the phone while you're on the road. Price is much of a muchness.
My opinions only.
Cheers Mick
AnswerID: 427738
Follow Up By: Vernp - Thursday, Aug 19, 2010 at 19:39
Landy
I have a set of Tyredogs and would not be with out it, on a recent trip to the desert there was a lot of 4x4s with shredded tyres because the road was that rough and corrugated that they never realised they had a flat tyre. My tryedogs paid for itself on that trip.
FollowupID: 698408
Reply By: Member - Warwick D (SA) - Thursday, Aug 19, 2010 at 17:38
Greetings. They are a great theoretical idea. I have Tyedog. For me, a very bad choice. Cannot change tyre pressures without removing them AND reprogramming the computer; signal operation very very variable; instructions as Inca translation of Minoan script, expressed in Latin...a task in itself.
You can buy my set of eight.
I hope someone has had a better solution. SOme of the imported Chey owners have them incorporated into the rim, and are pleased, easier to change pressures and recalibrate the warnings. I am still looking for a working retro fit system myself.
WD
AnswerID: 427739
Follow Up By: Roach"ee" - Thursday, Aug 19, 2010 at 19:48
I also got rid of the set-up I had a few years ago. It was called a Jette6 and whilst the concept was great, I'm sorry to say that my 55 year old brain just couldn't work out a quick/easy way to alter the settings after the pressures were altered for a change of terrain.
I will consider buying another set when a manufacturer comes up with a user-friendly system.
My idea of user friendly would see me doing the following:
1). Alter the rim by drilling another hole and fitting a second, short, rigid valve stem, close to the inner area of the rim so that the external sensor/sender would be safe AND not have to be removed when tyre pressures needed to be altered.
2). I would be able to fit the 6 sensors to my 4x4 and trailer, hop in the cab and press/hold a button (or a pair of buttons....sort of like a computer where you need to hold down Ctrl + Alt + Delete to perform some functions). Doing this would make the "brains" of the unit "seek-out" the current pressure and temperature of each tyre in turn.
3). Once I have seen all 4 (or 6) tyres register on the "brains" box, I could release the button/s and the system would be ready to go.
4). When I stop and alter my pressures, I simply repeat step 2 and the sensors would transmit their new "base data" to the brains box again.
For sure the sensors would need to have a stronger signal strength, as I was constantly losing the signal on my Jette system. Also, the small battery inside each sensor would need to be more easily accessible for replacement. The ones I had were a sealed unit and had to be "broken" open, rendering them difficult to re-use.
I will wait until such a system is put on the market.
Roachie
FollowupID: 698410
Reply By: AlanTH - Thursday, Aug 19, 2010 at 18:53
Hi Landy.
I've got a set of 4 Tyre Dogs which I used recently purely for highway use and took them off when dropping pressures off road. I reasoned that if anything happened at slow speed the tyre shouldn't shouldn't wreck itself.... well maybe not anyway!
Being able to see the rise in pressure on hot days was useful and I suspect I should have adjusted pressures downwards but didn't bother as they only went to approx 50psi on the Prado towing a camper and I didn't consider that excessive.
Good tool for keeping a check for high speed (our speeds anyway) work I think.
Cheers.
Alan.
AnswerID: 427748
Follow Up By: olcoolone - Saturday, Aug 21, 2010 at 18:04
I find TPMS are needed more when you lower the tyre pressure down, you lower the tyre pressure down when the terrain gets rougher, that increaser the chances of tyre damage plus with lower tyre pressures the tyre bags more making the side walls vulnerable to stacking.
FollowupID: 698641
Reply By: Robin Miller - Thursday, Aug 19, 2010 at 19:10
Also choose Tyredogs Landy - $182 on ebay (4 sensors)- never expected much and never got much.
I actually brought them simply for our Canning trip , in which I expected to go solo and as I only ever carry 1 spare I thought these would provide extra margin for error.
3 of the four sensors survived the Canning trip , the other died , but on made do by using rear view mirror which can see the rear drivers side tyre , and put good 3 sensors on the other tyre.
They are easy to live with , I note others concerned about ease of use - I found them quite easy and simply set them to alarm if PSI went below 18.
Unfortunately - no effective warranty for me - not that I expected one.
Apon examination I note that there construction and signal strength is not sufficent to give reliable readings on 4wds as used in bush.
Can be useful for touring though.
They our now available in Australia with 5 sensors for $400 , giving you a spare.
Robin Miller
AnswerID: 427749
Reply By: garrycol - Thursday, Aug 19, 2010 at 19:24
Do the internal sensors work with tubed tyres?
Garry
AnswerID: 427750
Follow Up By: Mick O - Thursday, Aug 19, 2010 at 19:38
No. You would need to use a screw on valve camp installation.
Mick
FollowupID: 698406
Follow Up By: garrycol - Thursday, Aug 19, 2010 at 20:33
Thanks - and as indicated above not really suitable for offroad without a b it of preparation.
Garry
FollowupID: 698423
Reply By: B1B2 - Thursday, Aug 19, 2010 at 22:44
G'day Landy,
I fitted the Tyreguard monitor, it was a lot cheaper than the Tyredog. I had no problem with airing down and up for dirt/off road and then blacktop. I also wanted to talk to someone who used them before buying them, which I did. He said he had lots of flat tyres but has never wrecked a rim since they were fitted.
One vehicle travelling with us had tyredogs and he blew a rear tyre and managed to stop before the alloy rim was damaged, the tyre was shredded.
Even if you don't take the time to adjust the pressures on the monitor, it will still give you a catastrophic loss of pressure alarm. I tow a tandem van and used 8 monitors.
I am happy with the system after about 6,000km in all conditions including heavy corrugations. If you save one alloy rim you are in front, never mind the inconvenience.
Bill
AnswerID: 427779
Reply By: Member - Boobook - Friday, Aug 20, 2010 at 07:17
I haven't bought a TPMS yet but have researched them and am almost at the point of buying.
I have narrowed it down to this one.
TPMS
THe reason is that it ticks most of the boxes for me.
4 or 6 wheels, extra units available for $50
The senders are sealed and though. I asked how tough at a show and they gave me one to do as I wish. I threw it on concrete about 5 -6 times and it survived. It was pretty impressive.
Mostly it has good alarms for fast pressure reduction and temp, and alarms at 25% down, 50% down and 75% down ( from memory). Being the screw on type I thing the temp will be a bit inaccurate. It is also pretty small.
I have nothing to do with this company but for me it looks as good as they get. Just wish it was cheaper.
AnswerID: 427801
Follow Up By: The Landy - Sunday, Aug 22, 2010 at 09:33
Thanks for the tip Boobook. I've done some more research on this one as it is starting to tick my boxes also.
Cheers, The Landy
FollowupID: 698687
Reply By: The Landy - Friday, Aug 20, 2010 at 10:15
Forum
Thanks to all who have taken the time to reply to date.
It seems plenty to work with, and if I get one take-away it is that the concept is ound, but the product offering is still lagging.
I will do a little more research into the products suggested over the weekend and will let you know how it goes...
Too many to respond individually, but to all, once again thanks!
Cheers, The Landy
AnswerID: 427822
Reply By: Member - Graham H (QLD) - Saturday, Aug 21, 2010 at 15:39
I have been using a set with 8 sensors and so far has saved 2 accidents in alerting me to tyre problems in time for me to stop without damage to rims of vehicles.
Mine are called SECUTIRE and are chinese made. Another member also has them.
After 60,000k of use the twofronts on the car are not reading BUT as pointed out by the supplier it can be caused by wear on the pins on the valve not activating the sensor.
I would agree with that as I changed two over last night and the one that was working on a rear wheel isnt on the front wheel that wasnt working prior to the change.
You can hear a little puff of air when screwing them down and the back ones give a noticably bigger puff than the two fronts.
Tomorrow I will replace the valve cores and see if it fixes them.
Apart from that they have performed well but as stated they are a bit of a pain if you often reduce pressures an appreciable amount.
It isnt hard on mine to change the alarm pressures but must be done for each wheel.
One way is to have the alarm set at say 18lb and just leave it If a tyre blows it will go off.
I think they are worth the money for what they are and on a tandem van are exceptional as you cant really tell if a tyre goes down.
AnswerID: 427935
Follow Up By: The Landy - Sunday, Aug 22, 2010 at 09:36
Thanks Graham
On another note, I am looking at the new HF Self-tune from Codan as they have designed to take account of changing regulations on bull-bar mounted units and 'view obstruction'. Whilst I have ticked the boxes on that previously Ithink it is only time before it wil be an issue having it bull-bar mounted in NSW. Already is in Victoria.
Also looking at TPMS range of pressure monitors..
Cheers, The Landy
FollowupID: 698689
Reply By: The Landy - Sunday, Aug 22, 2010 at 09:39
Once again, thanks for the many responses.
It appears one of the major issues that many have with this technology is failure from the transmitter on the wheel and especially from battery mounts breaking or dust/water ingressions. Also, ease of programming and monitor use has been flagged as an issue with some units.
I have done a bit more research on the TPMS range of product and they appear to have the transmitter issue covered by having a totally sealed unit that are replaced once the battery power has extinguished. And reading the product user manual it would seem that the programming is very straight-forward.
TPMS Range
I have sent a couple of questions to the company and currently waiting for a response.
I clearly need some sort of tyre monitor so it is a case of trying to get the right fit. The TPMS range appears more expensive than many of the other offerings. And whilst I’ve no problem paying good money for a good product, working out whether it is remains the million dollar question.
Cheers, The Landy
AnswerID: 428004
Follow Up By: The Landy - Monday, Aug 30, 2010 at 15:25
I purchased the TPMS monitor on the weekend, easy to install and use, and hopefully they do the job as described.
I must say that I spoke at length with a company representative the other day who answered all my questions confidently.
Cheers, The Landy
FollowupID: 699660
Follow Up By: Member - Brenton H (SA) - Wednesday, Sep 29, 2010 at 10:05
Just following up on your thread for tyre pressure monitors. The replacement time for my Sensatyres is almost up and keen to get some feedback on how the TPMS are going.
Brenton
FollowupID: 702552
Follow Up By: The Landy - Wednesday, Sep 29, 2010 at 10:50
Hi Brenton
Yet to be fully put to the test in terms of off-road, although I have done some tracks in the Watagans recently and all went well. Along the highway they have been fine.
I do notice some variance between tyres on the monitor despite being inflated to the same pressures, and maybe there is some temperature difference associated with this. However the reason I have them is not to monitor precise pressures, but to know when one has ‘blown’ and so far I am confident they will perform this task.
Good luck with your choice,
Cheers, The Landy
FollowupID: 702555
Follow Up By: Member - Graham H (QLD) - Wednesday, Sep 29, 2010 at 12:13
You will find the tyres on the sunny side will read about 3deg hotter than the shady side especially when travelling in a more or less straight line like as in Broome to Hedland.
Found that always happened.
FollowupID: 702557
