Ford Falcon for towing
Submitted: Saturday, Jan 02, 2010 at 17:47
Member - barry F (NSW)
Howdy Folks & happy New Year.
I need your valued comments & opinions please. We have a pop top van that when in travel mode would weigh in the vicinity of 1800-1900 Kg. We currently tow it with an 07 Mazda BT50 twin cab 4x2 manual, bought new & now has 40000 K on the clock. This vehicle has an ongoing clutch problem & will be out of warranty June 2010, so I am going to unload it sometime this year.
SWMBI drives a Camry for whatever it is that women do when they go out spending the "hard earned!!" Anyway, we are now of an age when we no longer realy need two vehicles.
So...... I'm thinking maybe a Falcon
sedan ( towing capacity 2300 Kg) as maybe a vehicle that would suit our daily & also our towing needs.
Any comments & opinions would be appreciated, Thanks.
Reply By: FredA - Saturday, Jan 02, 2010 at 18:06
i have a 05 ba auto
sedan i tow a 2000 kg pop top with. i have a 550kg weight distribution hitch. it drives
well, plenty of power, but it sits a bit low, probably really needs air bags or heavier springs in the rear. although the auto isnt meant to need a transmission cooler, the transmission overheats on long climbs, so i will be putting one on.
fred
397327
Follow Up By: Member - barry F (NSW) - Saturday, Jan 02, 2010 at 18:12
Thanks Fred, We used to tow a smaller van with the Camry Auto & a transmission cooler was a must & I thought that was the case with all autos?
Would you care to comment on fuel consumption, Thanks
666178
Follow Up By: FredA - Saturday, Jan 02, 2010 at 18:16
yes barry, fuel consumption on highway not towing is about 8 l/100, around town about 12l/100, and highway towing is around the 20-22l/100 sitting at about 90
fred
666180
Reply By: Member - Dalb (SA) - Saturday, Jan 02, 2010 at 20:01
Barry
I have had 5 company Falcons and found them to be fantastic towing vehicles when fitted with the factory fitted 2.2 tonne towing rig, which includes gearbox cooling.
I towed a 25ft 2.5t trailer sailer yacht and admit the rig was a little too large and too heavy, but more recently towed a 2t tandem offroad caravan and felt there was more than ample power, good control when the load levelling rig was fully wound up, and reasonable economy. On a trip
Adelaide to
Kakadu was achieving 17.9l/100km at 110 km/hr. I had a trip computer and strangely enough i got the sane economy at 100 and also at 80kph - so the motor was really just cruising.
cheers DalbImage Could Not Be Found
397340
Reply By: bruce - Saturday, Jan 02, 2010 at 21:04
We have a auto 96 ef wagon d/f ... overload springs on it ..tow a 1840kg laden dual axle poptop with ease and comfort and plenty of room...wdh on it and the van sits level , do not have to unhitch for over night stops..great car...er wagon..cheers
397354
Reply By: Wherehegon - Saturday, Jan 02, 2010 at 21:33
Get a valiant, heaps of low down grunt, LOL The falcon will do it with ease just add a tranny cooler or if you get the largest tow pack from ford Im sure it includes a cooler ?? Personally Im a holden fan BUT will always admit that ford have it when it comes to towing, more grunt. DONT go LPG for towing, friends have a dedicated LPG by ford (no petrol) and is a pig to tow with, a lot less power and drinks it like theres no tomorrow. You will appreciate the auto for towing to, no jerking between gear changes and take offs on steep hills no probs, plant the foot and let the auto do its job. Regards Steve
397364
Reply By: Road Warrior - Sunday, Jan 03, 2010 at 00:42
Firstly, any BA Falcon owner should have a trans cooler fitted regardless of whether you are towing or not. There is a design flaw in the factory trans cooling pipe in the radiator which needs to be bypassed and what better way to do this than with a trans cooler that will also help prolong the auto's life.
Secondly, if it were me, I would buy a wagon for this purpose because you will get the old-skool heavy duty leaf spring
suspension with the wagon (the sedans are IRS and squat in the bum when loaded up) which can give you up to 575kg of load capacity in the wagon load space alone. Better for towing too.
And yes, the factory e-gas system is crap, way down on power compared to the standard version (182kw compared to 156 on e-gas) which will make towing something heavy an absolute pain in the arse. It is also not a dual fuel system so if you're out in the regional areas and no one sells LPG, you're screwed. If you want gas, get a decent aftermarket system fitted. At least then you'll have dual fuel.
Oh, and I would probably lean towards getting a BF over a BA. The BA had too many design flaws - most of which were sorted with the BF.
397383
Follow Up By: Steve Ellis - Monday, Jan 04, 2010 at 09:13
I agree about the wagon but I believe they are no longer available new?
666403
Reply By: Olsen's 4WD Tours and Training - Sunday, Jan 03, 2010 at 11:23
Just be aware that at max tow mass, Ford says the Falcon is limited to 80kph max but then so is the Commodore and many others.
397419
Follow Up By: Member - barry F (NSW) - Sunday, Jan 03, 2010 at 16:47
Thanks everybody for your input, it is appreciated.
666287
Reply By: jamiel - Sunday, Jan 03, 2010 at 17:04
I tow approx 2000 kg with BF Rtv ute , halfway round aus now ,use about 19-20 litres per 100k also have gas conversion and notice no power loss when on gas. Usually tow in third gear rather than drive on advice of the guy who serviced transmission and to stop the car huntiing for a gear to settle on. Used a commodore ute for around aus trip three years ago and used 14-15 litres per hundred ks but the extra fuel used by the falcon is worth it for a much firmer secure feel on the road. Remember that the bit of fuel extra used for towing will add up to only one or two thousand dollars on a trip right round ,we spend more on cappuchinos, it is the everyday fuel usage at
home that might be worth considering over a few years and there is no significant difference between falcon and commodore when not towing. Might consider a v8 next time
397458
Follow Up By: Fatso - Sunday, Jan 03, 2010 at 21:18
Another point with the economics of towing is that you will buy a secondhand Falcon with 20 or 30,000 ks on it for anything up to $35,000 cheaper than a 4x4 wagon.
That will buy a lot of fuel.
666355
Reply By: jtw2005 - Wednesday, Jan 06, 2010 at 22:47
Hi Barry, We use a 2005 BA Mk II wagon to tow an 18' tandem poptop. We've been using this vehicle for 3 years now and have never had any issues. This has included 6000k to
Rockhampton and back a couple of years ago. We do have the 2300kg tow pack (was on the vehicle when we purchased it) but have added a separate transmission cooler, completely eliminating the issues with the standard cooler running through the radiator core (it's possible that if the core fails the transmission can end up full of water, very expensive repair). This was NOT included with the tow pack but cost only about $250 from memory. Have also added LPG and a Redarc isolator to charge the van battery whilst travelling. Fuel economy for the
Rockhampton trip averaged 18.5l/100k, mostly cruising at 95-100k for the whole. I do tow on LPG and even though it's not the new injection system there's still plenty of power. I do tend to use petrol in town and in hilly terrain. Having the LPG gives me extra range and cheap running around town. As has been mentioned the wagon is the best bet due to the leaf springs but I did go for the Futura - just that bit nicer. Ours was ex govt 18 months old and cost less than $20k, with only 30,000k on the clock. It's now over 100,000k and I've only needed to do tyres and a battery, just normal stuff. It does sit a little low in the back and I'm thinking of adding aurbags - approx $500.
In all it's been great and we are even considering going up the centre next year, including the Oodnadatte track.
Hope this helps you out.
398003
