Garmin Topo Australia - Just How Good????
Submitted: Saturday, Aug 29, 2009 at 10:56
ThreadID: 71860 Views:18776 Replies:16 FollowUps:39
I have always thought that Garmin had great products, and I thought that their "Topo Australia" would be up to their usual good quality - WRONG!
When we first purchased this additional Topo Maps for my GPS and Nuvi 5000, I thought that they would be great for our last Great Victoria Desert Trip. On the Black Top and in towns, it worked fine, but when we hit the Great Central Road, on our way towards Docker River, the maps has us driving for a very long time "Off Road", while the free to down load Shony Maps, loaded into another Garmin GPS had us spot on. This happened for most of the trip, and the Shonky maps for free could not be faulted.
I have since emailed Garmin, requesting a refund on a product that is not up to their standard - and you guest it, no reply.
My advise is save your money (RR$229), download the FREE Shony Maps and it will be spot on. That was my whole exercise, to have a product to should work when the normal street navigation units stop working.
Smile like a Crocodile
Reply By: Matt(WA) - Saturday, Aug 29, 2009 at 11:27
Hi Stephen,
I thought I had the same sort of issues with my nuvi. If you go into settings and select map, map info. Turn off city navigator. All of a sudden I had maps everwhere(Carnarvon Range and CSR)
It seems that city navigator overrides other mapping software
Matt
AnswerID: 380935
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Aug 29, 2009 at 11:43
Hi Matt
I had all the correct settings, only had Topo Maps on, and the City Navigator turned off, but they were out by a long shot. Sure it worked fine a few times, but for the money one pays, it should be as the same quality or better than Shonky, which is free. Like to emailed Garmin, The Great Central Road has been in place for many years and sees thousands of vehicles travel it yearly. I also offered to give them my saved track file from my Garmin Vista HCx, recorded at a rate for mapping, and still no reply, so they can compare the two files, side by side and to show them how far out their mapping is. The quality of the mapping needs a lot to be desired, where as the Shonky for free was spot on.
FollowupID: 648357
Follow Up By: Matt(WA) - Saturday, Aug 29, 2009 at 11:48
Cheers Stephen,
Obviously shoddy mapping software. I was amazed at how well shonky actually works. I brought a copy on a SD card, with some countours program, tracks 4 and something else for $15 dollars. It had all the info I needed for where we have been latley.
Matt
FollowupID: 648361
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Aug 29, 2009 at 13:11
Hi Matt
It is nothing to do with Shoddy Mapping Software. The Micro SD Card is pre installed when you buy the product from Garmin, just install into any Garmin product that supports the additional mapping, go into settings, maps, change the info so Topo Australia is the preferred maps and enter. Like I said, I had one unit running Shonky, so I could compare the two mapping systems. It all comes down to the fact that Garmin still have to do a lot of work to get their mapping system spot on.
What amazed me was the fact that I have offered them the correct data to compare, but have not had the decency of a return email.
FollowupID: 648375
Reply By: Member - Tony V (NSW) - Saturday, Aug 29, 2009 at 11:43
I'm with you Matt,
the only issue seemed to be with City Navigator being turned on.
Yesterday I put installed Mapsource on a friends computer and hooked up my Garmin Nuvi 760. I transfered the trip I did on Thursday in the Watagans and rotated through Trips4Australia, Shonky, CityNav and Garmin Topo.
The Topo was the only one that showed all tracks.
As a note, make sure that you have the highest definition turned on as well.
AnswerID: 380937
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Aug 29, 2009 at 11:58
Hi Matt
I am well and truly up with using these products, we sell them at work. It is not the units ability, but the quality of the mapping.
FollowupID: 648363
Reply By: fuji - Saturday, Aug 29, 2009 at 13:48
Hi Stephen The same thing happened with me after travelling the simpson desert. If it wasnt for travelling with other cars that were running oziexplorer I would still be in the desert.
AnswerID: 380945
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Aug 29, 2009 at 13:55
Hi Fuji
It sounds like it is out more that one would expect. If it is out for the very easy Simpson Tracks, it makes one wonder what other areas are out as well.
FollowupID: 648384
Reply By: fuji - Saturday, Aug 29, 2009 at 13:50
On the way home the map had us travelling through paddocks when I should have been on the Calder
AnswerID: 380946
Reply By: AlbyNSW - Saturday, Aug 29, 2009 at 14:20
I purchased the Topo maps for my Garmin Nuvi 660 for my recent trip to Cape York.
I found them next to useless, 90% of the time is would just say "travelling north on track" or words to that effect, even on the OTL, Frenchmans track etc...................I can look out the window and see that!!
I wanted it as a confirmation of where I was but it failed to do that, nor does it name any river crossings. I was even on the Jardine Ferry and it had no idea???
I would love for someone to tell me I was doing something wrong but apparently that is how it works
AnswerID: 380948
Follow Up By: age - Saturday, Aug 29, 2009 at 14:46
Hi Alby
Just did a check in Mapsource of Shonky, Topo Australia V2 and Oztopo 2.1b on an area where the Jardine and the Alice Rivers meet. You are right - Topo Australia has pieces of the Jardine totally missing - in this area Shonky is the most detailed with some fence lines etc marked and Oztopo a little better than Topo Aus. Just strange that chunks of data are missing in Topo Aus.
A
FollowupID: 648389
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Aug 29, 2009 at 15:37
Hi Alby
It sounds like that Garmin needs to re do their homework and very fast. When I spoke to our Garmin Rep and told him about my issues, and that I could not sell their product in confidence, he did not like it and then put the blame back on HEMA, who have supplied Garmin with the Data. It would not be in the interest of HEMA to supply wrong data, as all their maps are spot on.
I think that Garmin should get their maps up to date and supply all of us that have the bad maps with ones that work the way they should - or do as I will now do and advise all people to save their hard earned money, download Shonky for FREE and have a map that shows you where you are.
FollowupID: 648395
Follow Up By: Michael ( Moss Vale NSW) - Saturday, Aug 29, 2009 at 15:43
I made the same comparison a few weeks ago at the northern point where the CSR starts.. It shows a 1.6 km solid line of the CSR and it issign posted as such, but it is just a short line and stops..... The CSR than goes to a track (broken line). No mention of the CSR a little lower when the cursor is placed over the CSR, or written alonside it, just says track and i checked all the maps from 800mtrs to zoomed right in to the highest resolution and nothing, It may be sign posted down further but not at the top end.. You would be hard pressed just using just Garmin topo to get you on the right track if heading south.. Doug T showed some me some sign posted sections but they must be lower on the CSR. CSR is definitely not defined as well in Garmin Topo as other maps for garmin and i dont think you should have to be zoomed right in to be able to see signposted roads. Looking at a large line in the middle of the screen serves no purpose at all.. My other complaint is if you buy Garmin on SD card, the maps are 1,8 gig placed on a 2 gig card, there is no room for music, very short sighted.. Im fairly new at this, maybe i have it all wrong, but i dont think so!! Michael
FollowupID: 648398
Reply By: Member - Sigmund (VIC) - Saturday, Aug 29, 2009 at 17:44
Using paper topo's as a benchmark, 50k and 100k, I judge the Garmin topo to be a long way from a substitute, and wouldn't rely on it for navigating the Vic alps area.
AnswerID: 380961
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Aug 29, 2009 at 18:13
Hi Sigmund
I always use OziExplorer as well and thought that I would be on a par when used off road. I had a good success with it on Lindsay Island but was next to useless past the Docker River turn off. After another person in the group was using a Hema Navigator, that would be the way to go, if only a larger screen.
FollowupID: 648418
Reply By: oldpop - Saturday, Aug 29, 2009 at 18:29
Hi guys
Almost given up with my 760 does not work properly have not tried in bush yet most times it is real slow ad has me travelling along besides the roads I am supposed to be on going back to the old school map and compass
Oldpop
AnswerID: 380969
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Aug 29, 2009 at 19:05
Hi Oldpop
Have you tried a firmware upgrade from the Garmin site, as your Nuvi 760 is a top unit and should not be performing like that. My issue here is not with Garmin GPS units or Nuvi units, but the Garmin Topo Australia maps sold as an add on for off track use, and better remote area tracks.
I hope you get your problem sorted.
FollowupID: 648429
Follow Up By: oldpop - Saturday, Aug 29, 2009 at 19:17
updates are current done last weekend but still no joy travelling along one section of road near home wants me to do several left hand turns over 3 metre drop off. Stop in driveway at home shut down car get ready to get out car still doing 6-8 K.P.H
Oldpop
FollowupID: 648430
Follow Up By: Michael ( Moss Vale NSW) - Saturday, Aug 29, 2009 at 19:29
Oldpop, start logging your problems and take it back, im sure they will just change it for you.. I wouldnt put up with a faulty unit. My first Uniden 501 said i was doing 180kph, sitting at the lights, the speeds and distances were all over ther place, the shop (ebay shop) just exchanged it no problem.. Michael
FollowupID: 648435
Follow Up By: oldpop - Saturday, Aug 29, 2009 at 19:47
Michael
Have spoken to the experts at DSE not really interested Have emailed Garmin no reply maybe next is a personal visit with couple of heavies
Oldpop
FollowupID: 648440
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Aug 29, 2009 at 19:59
Hi Oldpop
I am sorry to hear of your problem. The Garmin units are top units, but the service from Garmin needs a lot to be desired, compared to when Standard Communication were the Australian distributors when their service was first rate.
DSE should be able to sort your problem out, do not just speak to the salesperson, request the Manager.
All the Best
FollowupID: 648443
Follow Up By: oldpop - Saturday, Aug 29, 2009 at 20:16
Stephan
Only updated from a 250W to get the TTS and blue tooth option and have fitted an extra radio and speakers to handle FM transmtter and mobile phone not happy jan
the 250 was really good
Oldpop
FollowupID: 648445
Reply By: oldpop - Saturday, Aug 29, 2009 at 20:38
Where is Doug T he is the garmin guru
Oldpop
AnswerID: 380997
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Aug 29, 2009 at 20:50
Hi Oldpop
I would say that he is not too far away.
FollowupID: 648449
Reply By: warfer69 - Saturday, Aug 29, 2009 at 20:41
Hiya Steve
This is interesting because for the driving i do through the High Country its pretty well spot on with my other software.I have Mag XL unit also with Topo Aus and i havnt found anything as good yet and confirmed by mates.Although Garmin Topo its very close for this area,and i thought lovely on the eye too.
Pathetic service considering your offer of help,Just like other Companies and i thought they had changed from the ol, the manufacturers know best instead of the Customer but obviously not.
Goodluck with it...
AnswerID: 380998
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Aug 29, 2009 at 20:48
Hi Warfer69
Lets hope that the above comments come to the attention of someone from Garmin and it makes them get up think, that they should listen to their customers and also take up my offer so that their cartographers can compare my correct data, with the data that they have, that is very inferior.
FollowupID: 648447
Reply By: bob&loz - Saturday, Aug 29, 2009 at 22:06
I have a nuvi 5000 loaded with city navigator, topo V2, tracks 4 aust pro and shonky. I have found that the topo is good in some areas but has a lot of roads missing altogether in most areas.
I usually use city for when I am in towns. T4A when travelling and want to have the unit zoomed out a lot as it shows more detail at lower zooms and shonky when detailed navigation is required in the bush as I find it the most detailed and accurate.
Also find that the topo is hard to read as the roads are not very distinct against the background.
I would not recommend anybody to buy it.
AnswerID: 381018
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Aug 29, 2009 at 22:40
Hi Bob
Sounds like we both think the same. When you think that Shonky maps are free and far better quality, Garmin have a lot to answer for.
FollowupID: 648465
Follow Up By: Michael ( Moss Vale NSW) - Sunday, Aug 30, 2009 at 09:27
Bob, I made the same comment a few weeks ago, the cotour lines are to thick and distinct, they should appear as a watermark and not blend in with the roads.. Michael
FollowupID: 648495
Reply By: Member - Doug T (NT) - Sunday, Aug 30, 2009 at 11:39
Go and learn how to use it, I have overlayed recorded tracks from Arnhem Land and Gregory NP and I find it much better and more accurate than City Nav' 2010, and if you can't find the Jardine Ferry by using your eyes there's something missing ...???
AnswerID: 381082
Follow Up By: Member - Stephen L (Clare SA) - Sunday, Aug 30, 2009 at 12:50
Hi Doug,
I do not have to go and learn how to use it! The Garmin Topo Australia is long way out when it comes to the accuracy of the data supplied from Garmin. I am well an truly qualified to comment, as I do freelance mapping for on of Australia's major mapping companies, so I know when a map is accurate or not and what I am talking about. When the units show me travelling for much of the Great Central Road "Off Track" and Shonky has me spot on, you tell me which one is correct? After all, if the Garmin Topo Australia was spot on, why do two GPS Units show otherwise.
How do you have to learn how to use it. It is as simple as inserting the SD Card into the Nuvi 5000, settings, maps, untick city navigator, I have map units set to the highest quality. It was also the same when I have it in the GPS Map 60CSx.
I am sorry Doug, but I am 110% correct with my comments and Garmin are the ones that will have to lift their game and supply a product that is what we all pay for.
FollowupID: 648524
Follow Up By: AlbyNSW - Monday, Aug 31, 2009 at 09:52
Doug T.
I know I was on the Jardine River, I had just paid $88.00 for the ferry ride.
The point I was making was that it did not identify any of the river crossings, including the Jardine. Apart from referencing GPS co-ordinants (which you can do without the OZtopo software) back to a hard copy map there is no way of determining where you are positioned.
For the record I have the V2 system. Upon my return from the Cape trip I questioned the system from where it was purchased and the excuse was a combination of the map data that is provided and the way the Garmin Nuvis software operates.
It is dissapointing to hear the 'blah blah blah' line. I paid for the premium product thinking that it would be superior to the free software options as I just wanted to get something that works without any hassles. ( i could just imagine the grief I would be copping from the Mrs and family if we were lost in the bush because I was relying on some shonky free map system to find my way round)
Sounds like my best intentions were not correct anyway. You do not always get what you pay for.
FollowupID: 648659
Reply By: Member - Jeff O (VIC) - Sunday, Aug 30, 2009 at 15:28
Stephan
I have a Nuvi 5000 with OzToppo.
Just returned from Mel to Darwin via William Creek, Alice, Borroloola, Simpson Desert ,Nhulunbuy etc, .On most bush tracks it showed me off road . A lot of places I went to weren't listed.
The Nuvi is ok but the OzToppo in not worth a cold pie..
Maybe I 'm not driving it correctly?
AnswerID: 381110
Follow Up By: Member - Jeff O (VIC) - Sunday, Aug 30, 2009 at 15:38
Sorry
I made a mistake. I have TOPO Australia in my Nuvi 5000 not Oz TOPO.
FollowupID: 648537
Follow Up By: Member - Stephen L (Clare SA) - Sunday, Aug 30, 2009 at 16:26
Hi Jeff,
Like I said above, I am very happy with my Nuvi 5000 as well, just the fact that we pay very good money for very poor mapping that is out a very long way.
It sounds that you are like the rest of the people here that have problems with the quality of the Garmin mapping.
We will all have to now see what Mr Garmin has to say.
FollowupID: 648540
Reply By: Mrbrush - Sunday, Aug 30, 2009 at 15:37
This is all very interesting, as when I use my shonky maps it seems to be off track up to 40metres at a guess quite often.
Worst thing now is I just bloody Garmin Topo V2 !!!!!!!!!! to fix the problem.
Have I just wasted my money ?
AnswerID: 381113
Follow Up By: Member - Stephen L (Clare SA) - Sunday, Aug 30, 2009 at 16:35
Hi Mrbrush
To answer your question,I am afraid so. You would have been better to stick with Shonky maps. At least you can see where you are, not driving on a well used track, that Garmin Topo Australia has you driving "Off Road" and no tracks at all.
My reason for this post is to save people money that are thinking of buying this poor product from the Garmin.
FollowupID: 648541
Reply By: Isuzumu - Sunday, Aug 30, 2009 at 16:58
Hi Stephen, I to am disappointed with the Topo Maps, I have a Nuvi 760 with Shonky and I have found it to be better. But what I have found to be better than both is my Magellan DiscoverAus, which is old now running on my old Meridian Gold. I also have Ozi running on my EeePC 901 and quest what I can run my DiscoverAus on it as well ( I have a BU 353 GPS on the Eee) Even though I have paid for the Topo mapping I can not use it any where else, so would I buy another Garmin I don't think so.
18 months ago I paid around $1000 for the 760 with the topo map and a mate brought just the 760 from DSE the other day for $378 LOL
AnswerID: 381127
Follow Up By: Member - Stephen L (Clare SA) - Sunday, Aug 30, 2009 at 17:18
Hi Bruce
I always like Garmin products, as we sell them at work and I know of the quality of their products. I am afraid that the Topo Australia by all the replies above is not just confined to one area, the whole of Australia in general. We still have stock at work and I am afraid that I will not sell them on principal alone.
How could I tell a customer that they are great when I know better.
I think that this is a real Lemon for Garmin
FollowupID: 648545
Reply By: Mrbrush - Sunday, Aug 30, 2009 at 18:29
Hi stephen, I missed a word in my previous post. I was meant to say I just bloody" BOUGHT" garmin Topo to fix the same problem I get with shonky.
And unfortunately it is in the mail on its way.
But as I said I bought this hopefully to remove the same offtrack problem I am getting with shonky maps.
To me it seems that when these programs were created they have stuffed up with their coordinate sytem so it displays everything offset against the sattellite coords picked up by the GPS unit.
Just a thought.
Cheers.
AnswerID: 381140
Follow Up By: Member - Stephen L (Clare SA) - Sunday, Aug 30, 2009 at 18:34
Hi Mrbrush
When it does work, it is good, but when it does not, the shonky is far better.
FollowupID: 648556
Follow Up By: Mrbrush - Sunday, Aug 30, 2009 at 20:26
Stephen, Would you know what version 2 has against the original ?
Also, Earlier this year I went over to nth stradbroke island, and we travelled across this well used sand track that traversed through the centre of the island, its been there for years at a guess, But shonky maps did`nt have it ?
FollowupID: 648578
Follow Up By: Member - Stephen L (Clare SA) - Sunday, Aug 30, 2009 at 20:39
Hi Mrbrush
I am not aware of a Version 2 being released as yet, as the first release was only early this year. As for the tracks on Stradbroke Island, I am sorry but I could not comment, as I have not been there, but for a free map, it may only be a small issue, compared to many issues with large areas on well travelled parts of Australia on the Garmin Topo Australia.
FollowupID: 648582
Follow Up By: Member - Stephen L (Clare SA) - Sunday, Aug 30, 2009 at 21:16
Hi Mrbrush
When I spoke to our Garmin rep last week and complained, he made no mention of V2 and did admit that there were issues with Topo Australia. When I looked at getting a copy, as expected, he was of very high praise of the product.
FollowupID: 648590
Follow Up By: Mrbrush - Sunday, Aug 30, 2009 at 21:39
The question is, why does`nt your rep know about a version 2, when its on on ebay ?
I went to the garmin site and could`nt find any version 2 either ?
FollowupID: 648597
Follow Up By: That Troopy Bloke (SA) - Sunday, Aug 30, 2009 at 22:27
Well, that solves that little mystery for me.
Here I was, thinking you guys were on drugs or something :-)
I've found Topo Australia to be far better than Shonkymaps.
But I've got V2....I didn't even realise that there was an older version.
Haven't had much of a chance to try it out in the field on my Nuvi yet.....but in Mapsource it does show more tracks than shonky and t4a.
But there are a few tracks in shonky that topo aus doesn't show.
It does autorouting too. I'm happy with mine.
Glenn
FollowupID: 648610
Follow Up By: KennyBWilson - Sunday, Aug 30, 2009 at 22:45
The first and current version is called Garmin Topo Aus V2 , Version 1 never was released to the public
FollowupID: 648616
Follow Up By: Member - Stephen L (Clare SA) - Sunday, Aug 30, 2009 at 22:49
Hi Glenn
I am not sure if the V2 is an upgrade of the First release. Like I said above, our rep made no mention of a fix or a release of an upgraded version. If you are like me, I did have a play with it and looked fine, until you hit the unknown and the tracks that should be there, well they are not where they should be.
It would be very interesting to see if V2 gives the same results on the Great Central.
FollowupID: 648617
Follow Up By: Member - Stephen L (Clare SA) - Sunday, Aug 30, 2009 at 22:51
Hi Kenny
At least that solves that issue,so there is no upgrade at this time.
FollowupID: 648619
Reply By: Member - Doug T (NT) - Monday, Aug 31, 2009 at 11:17
OK so I relented and decided to have a look at this shonky map stuff, I downloaded the 337 MB file , from I can see it doesn't matter what map software you use you'll find one has something the other hasn't, shonky has some good features ...yes , I guess it would be better than T4A but I'm glad I had the Garmin for the recent trip in the Gregory NP , but once again they both have tracks they other does not, I also noticed when I checked the track record across Arnhem Land that the Garmin Topo is more accurate because my gps track is spot on where as the shonky was off line a bit, I'd say they are both at 87% , in fact the shonky looks like a carbon copy of the Garmin , below is a section of Gregory NP showing part of the Humbert track on Shonky, on Garmin, and garmin with my recorded track overlayed ,
Image Could Not Be Found
AnswerID: 381238
Follow Up By: Member - Doug T (NT) - Monday, Aug 31, 2009 at 11:28
And as for the town of Adelaide River , Shonky is a copy of T4A.
So no more BS about what's good and what's not ,
FollowupID: 648668
Follow Up By: Member - Stephen L (Clare SA) - Monday, Aug 31, 2009 at 14:43
Hi Doug
Thanks for that. In the areas that it did work, it was great and spot on. My issue hear is that many of the tracks in the Great Victoria Desert Area, including the Great Central Road out from Yulara. At one stage, when travelling about 80kph, we lost all track on the Garmin Topo Australia, full satellite signal, yet Shonky still had us on track, a fact that lasted for nearly half an hour, still showing all the contours, but having us travelling "Off Road". I have spoken to a helpful lady at Garmin today, forwarded my emails that I have sent and she is going to talk it up from here.
Like I have said, Garmin make top quality GPS units, I have 4 of them including the Nuvi 5000, yet the quality of Topo Australia lets their quality down.
FollowupID: 648701
Follow Up By: Member - Doug T (NT) - Monday, Aug 31, 2009 at 14:50
I just checked my copy of the GCR on Garmin Topo and it's 1 contiuous unbroken line from the Olga's to Laverton, your copy must be faulty,
I do notice however the QAA line is not complete ,
FollowupID: 648703
Follow Up By: Member - Stephen L (Clare SA) - Monday, Aug 31, 2009 at 20:34
Hi Doug,
I do not think that is a fact of a faulty maps, more like that the data that they have is faulty and way out of where the actual road is. I can go to my GPS, zoom out find the correct roads, but when you get out there and travel the actual route, that is when the problems start.
FollowupID: 648768
