UF2020 Pearce Simpson
Submitted: Saturday, Sep 09, 2006 at 09:09
ThreadID: 37564 Views:3378 Replies:4 FollowUps:1
Hi i was wondering if anyone had info or could tell me where i would find the duplex button on an UF2020 Pearce Simpson radio. thanks Ash
Reply By: Tony Middleditch - Saturday, Sep 09, 2006 at 09:42
Ash, send me your email address & I will dig up the copy of the operators manual that I scanned.
Cheers Tony, VK3CAT
AnswerID: 193657
Reply By: ash05 - Saturday, Sep 09, 2006 at 09:51
Thank you your a champ its ashkate@dodo.com.au Thanks Ash.
AnswerID: 193658
Reply By: ash05 - Saturday, Sep 09, 2006 at 13:04
Thank you for the doc Tony, now looking at the mannual i have realised there was no way i was going to get it to work properly without the manual.
AnswerID: 193681
Reply By: ash05 - Saturday, Sep 09, 2006 at 14:03
Hi Tony with the scanner mode does it automaticly pick the Frequency up when its in the 99 channell mode or do i need to some how specify a Frequency for it. Regards Ash.
AnswerID: 193685
Follow Up By: Tony Middleditch - Saturday, Sep 09, 2006 at 17:57
Ash, in scan mode it will scan either all of the 40 or 99 channels if you have them (the 99 channels selected)
You can save a channel above ch 40 as a priority channel & then revert back to the standard 40 channel setup. You should also be able to set up a memory channel scan but haven't looked at this for a long long time.
Unless your police services are using the analouge services, then the police receive will be about usless.
For what it is worth, in rural areas in Victoria, the police either still use UHF with an automatic translator on VHF (164Mhz) or are using the VHF radios which can be heard from translators in the Metro area.
Tony
FollowupID: 451612
