WARNING- Oil catch cans & Diesel Engines
Submitted: Thursday, Dec 22, 2005 at 10:52
ThreadID: 29080 Views:70106 Replies:6 FollowUps:10
Oil catch cans will cause problems for a diesel engines if fitted.
oil catch can this is the one that I bought
About 300km ago I fitted one to my Turbo diesel Nissan Terrano, thought it was a good idea and nobody told me it wasn't.
Basically all oil catch cans have small 1/4 inch piping, which is totally inadequate to handle the larger volume of blow-by air that a diesel engine produces. (Due to the higher compressions).
Due to the restrictions that the small dia piping has, I was effectively pressurising, tapot cover, sump, all oil lines, turbo etc...
So only after 300km, my turbo let go, the oil seals busted out and dumped huge amounts of oil into the inlet side of the turbo. The turbo is currently being rebuilt by the blokes at MTQ in Rockhampton.
As soon as they opened the bonnet they knew what had caused the turbo to fail. They specailise in turbo diesel engines and the like. There solution to the problem is that they use common old 1" line strainers, (The same things you can find at any local pumping and irrigation business)
line strainers
So inclosing, if you have bought and fitted one to your diesel, rip it out.
P.S. if anyone thinks I am wrong, in any of this, by all means post something.
SantaAus
