How to Add Photo's to a Reply !
Submitted: Wednesday, Oct 21, 2015 at 18:48
Robin Miller
I give up , it used to work fine , but now as a logged in member I cannot figure this out.
(using Win 7 IE9)
To Add Photo's into a reply I first select "Images and Files" and the Embed image menu comes
up and you select "Add Photo's & Files" which allows you to select a photo from your PC.
You then wait a few seconds for your image to upload and then menu "Gallery Item 1/1" appears.
You then type in a mandatory field "Title" then select "Save"
The message "saving" appears briefly and then you are tranferred back to "Reply to thread ".
Normally at this point the photo's index number would appear however the "Reply to Thread "
window now remains blank for me !
Reply By: The Explorer - Wednesday, Oct 21, 2015 at 19:05
Does this work
Great Victoria Desert - Oct 2015
591809
Follow Up By: The Explorer - Wednesday, Oct 21, 2015 at 19:11
Would appear to be working for me..which would suggest problem is your end..
Breakaway - Great Victoria Desert - August 2015
Win 7 / Mozilla Firefox latest...do people still use IE :)
859849
Reply By: Idler Chris - Wednesday, Oct 21, 2015 at 19:09
On the runway
Looks like it works for me. (Using Win 7 & Chrome)
591810
Reply By: ExplorOz Team - Michelle - Wednesday, Oct 21, 2015 at 19:33
I'm wondering Robin if perhaps you haven't put your cursor into the reply box first before hitting the Images button??
591811
Follow Up By: Robin Miller - Wednesday, Oct 21, 2015 at 19:41
I will
check that with this follow up Michelle - it has to be something I'm doing or use as it does work for others as per above.
No it wasn't that - it certainly goes thru the motion of image saving but that index nuber never appears like it used to.
Thanks though .
859851
Follow Up By: Robin Miller - Wednesday, Oct 21, 2015 at 19:51
Davenport Inlet - a favorite place
Ok looks like this will work.
To make it work I changed to google chrome and went to Exploroz which required me to login and this caused some changes.
Assumption - I was not logged in properly an hour ago.
How do I know I was logged in before ? I clicked on the
forum member and profile buttons and they said I was me !
Either that
test has a loophole or IE9 was the problem - after this post I will post a follow up using IE9 with a photo.
859853
Follow Up By: Robin Miller - Wednesday, Oct 21, 2015 at 20:04
Ok It did not work with IE9 but now I know more.
I noticed that when I clicked on this post to followup , with IE9 the followup box was completely blank.
However when I did this with google chrome the followup window contains the greyed out text "Enter the body of your followup"
Clearly the browsers react differently.
What is interesting is that I have done other followups using IE9 and they work.
Conclusion is that the issue allows text thru in IE9 but would not embed an image.
So I have a work around for now - thanks to all.
859854
Follow Up By: ExplorOz Team - Michelle - Wednesday, Oct 21, 2015 at 20:11
Brilliant analysis & process, good one Robin. I will alert David to read this when he gets a chance and I'm sure he will know what to do.
859855
Follow Up By: The Explorer - Wednesday, Oct 21, 2015 at 20:15
Hello
May not help, but why are you using IE V9 when it is now up to V11? Updating to the latest version of anything doesn't not always result in a positive outcome but using most recent version of the browser in question may
well solve your problem (if you wish to persist with IE). David may be trying to solve a problem that doesn't really need solving.
859856
Follow Up By: ExplorOz Team - Michelle - Wednesday, Oct 21, 2015 at 20:15
Just a thought - the latest IE is version 11...
859857
Follow Up By: muzbry - Thursday, Oct 22, 2015 at 09:01
Gday
you need more cafine robin.. Solves lots of problems.
859875
Follow Up By: ExplorOz - David & Michelle - Thursday, Oct 22, 2015 at 12:28
Robin,
IE 9 will certainly have a problem with the PlaceHolder text - this is the Type your Reply
grey text. It was just not supported. I did make a few sweeping functional updates across the system that will have reduced support in older browsers and IE 6,7 & 8 will basically not work
well at all. IE 9 should work OK and the image upload
tools were not really changed going to the new layout however the bottom end jQuery library was updated which may have caused a problem. I know IE: 10 + work perfectly but I am a little curious about why IE9 plays up. The function that would seem not to work is the bit where it pastes the GI tag into the text box - Weird.
Did the Saving Save - your image was saved?
David
859889
Follow Up By: Robin Miller - Thursday, Oct 22, 2015 at 12:50
Hi David
I thought IE9 was still supported but either way don't go to any trouble on my behalf.
I note that IE is still the 3rd most popular browser at about 8% however only 1% are using IE9
P.S. It did say "Your Image has been saved " however , it did not count up the bytes as it was loading.
859895
Follow Up By: ExplorOz - David & Michelle - Thursday, Oct 22, 2015 at 13:10
Robin,
Yes that would be expected the byte count is a HTML 5 function and came in to IE10 (Microsoft was not with the standards until the last year or so). But it is strange that the sending of the text to the box did not work - it is really a simple piece of code and I did not change it from the previous versions. I will double
check the script to be sure.
Thanks and have a good one.
David
859900
Follow Up By: ExplorOz Team - Michelle - Thursday, Oct 22, 2015 at 13:12
Hi Robin, interesting you mention the rank popularity of IE. ExplorOz Google Analytics show 35% use Chrome and 35% use Safari. 15% use IE (with 80% using V11 and only 8% on V9). Firefox is lagging at only 8%, and 2% use the Android browser. Whatever browser people choose, there is a setting in all browsers to automatically update to latest version - this is very important.
859901
Follow Up By: Bosun Broome - Saturday, Oct 24, 2015 at 09:01
Where is Davenport Inlet please?
860003
Follow Up By: Robin Miller - Sunday, Oct 25, 2015 at 09:42
About 45km south west of
Ceduna - past Denial bay.
You can drive (4wd) to the actual point on the picture I posted , the point is called PT Peter.
860034
Reply By: Member -Dodger - Thursday, Oct 22, 2015 at 13:59
Loooong Truck
I hope this has worked for me , IE posting the image.
Would not like to meet this truck on a narrow winding road.
591852
Reply By: Nomadic Navara - Monday, Oct 26, 2015 at 15:43
I notice that all pictures above are posted in a standard minimum size frame. I posted several .JPG files in the thread
Caravan weights, the heights of these was less than 1/6th of the frame size.
Is there any way we can reduce the frame size to fit the graphics/picture?
Is there any way
forum software can be modified to produce the frame size to fit the graphic?
591980
