Sunday, Dec 01, 2013 at 22:18
i'm not technical, i got a caravan guy to install it i just thought people might know what's normal for this mppt controller... it's a pretty common one available and it's been mentioned here before
does the absorption phase do this on regs? is this totally abnormal?
it was charging steadily in the morning when the sun came up and then went into float mode where it was showing 50w.
then in the afternoon after using some power i noticed it was doing that. After a while it went into float mode again and settled down...
I was running a 1700w coffee machine and a battery charger, it was also 30c today in case that might have something to do with it.
I have 2x150w 12v (18.5v nominal voltage? )solar panels (in parallel) running into 2x120ah batteries. There is a matson battery charger for shore power, a 2kw pure sine wave inverter.
803516
