The dangers of winter diesel
Submitted: Saturday, Jul 27, 2013 at 13:45
pepper2
Has anyone read the above artical in the "
snowy river echo" essentially a local mechanic advises that the anti waxing/anti gel constituent has been removed from alpine diesel resulting in diesel becoming solid in temperatures below minus 4 deg c,if accurate this would pose enormous problems for diesel powered equipment and vehicles.
Reply By: garrycol - Saturday, Jul 27, 2013 at 13:51
Don't believe eveything you read - more likely vehicles coming to the region from areas where winter diesel is not needed and arriving in the mountains with normal diesel in their tanks and suffering the consequences.
Garry
515433
Follow Up By: Member - Allan L2 - Sunday, Jul 28, 2013 at 08:24
Spot on, I have to agree with you Garry. If you are visiting & staying overnight in Alpine areas make sure you top up with local diesel. Try to arrive with a relatively low tank level so as to top up with the maximum amount of alpine fuel. Remember, the locals drive diesel powered vehicles & don't have problems. I have been staying in the
Adaminaby,
Jindabyne, Thredbo area during mid winter for many years & as yet not experienced any problem. I have known of many that have had trouble & most have arrived from lower altitudes & generally further north west & not topped up locally.
794749
Reply By: Nomadic Navara - Saturday, Jul 27, 2013 at 14:20
ere is a bit on diesel fuels. The standards for Oz diesel are
in this link. Scroll up to see what the terms mean.
515436
Follow Up By: racinrob - Saturday, Jul 27, 2013 at 17:53
In May earlier this year we overnighted at
Wallabadah south of
Tamworth NSW, it got so cold during the night it froze the water in our caravan's water pipes. Around 8 o'clock the next morning I fired up my old 75 series LandCruiser with a fair bit of white smoke but it did start whereas a couple of late model diesel Pajero's would not. The Pajero drivers rang the NRMA in
Tamworth who advised them to wait until mid morning when the temp had risen a bit and try again, evidently common rail diesels don't like the cold with normal diesel fuel.
rr
794723
Follow Up By: pepper2 - Sunday, Jul 28, 2013 at 08:07
peter thankyou for your thoughtful reply
794747
Reply By: Ross M - Saturday, Jul 27, 2013 at 17:50
If it hasn't got the anti waxing.gelling agent then it isn't Alpine Diesel. What else makes it ALPINE.
515440
Reply By: Witi Repartee - Saturday, Jul 27, 2013 at 19:51
Can't see any link to the story above. Would be handy. Cheers
515447
Reply By: Smiley Bill - Saturday, Jul 27, 2013 at 20:32
Hi all,
Alpine diesel is normal diesel mixed with Heating oil.
SB
515451
Follow Up By: The Original JohnR (Vic) - Sunday, Jul 28, 2013 at 13:04
Heating oil is diesel mixed with a small percentage of kerosine.
794769
Reply By: pepper2 - Sunday, Jul 28, 2013 at 08:07
thankyou for your replies
515463
Reply By: cookie1 - Sunday, Jul 28, 2013 at 09:35
I'm going to the
Vic High Country in November and should arrive there from
Adelaide on the one tank then top up locally, the question is though, given that I take 270 +litres in my tanks is there a problem if I run Alpine Diesel once in a warmer climate, start heading
home back to
Adelaide?
I have a 200 GX Cruiser if that makes a difference
515468
Follow Up By: fisho64 - Sunday, Jul 28, 2013 at 10:28
do you need to put 270 litres of Alpine in? Given it is likely dearer than summer fuel anyhow?
794762
Follow Up By: cookie1 - Sunday, Jul 28, 2013 at 10:41
Thanks for that - it is more of a comment than answering my question but there you go...
No I don't to fill all the way up, but then I try to support the locals where I can, I also don't know how much fuel I will use whilst in the area
I still want to know if the Alpine / Winter Diesel will present any issues in the warmer areas - appreciate an answer instead of comments please
794763
Follow Up By: fisho64 - Sunday, Jul 28, 2013 at 11:11
Sorry for commenting. Short term no problem. Long term the fuels lubricity/thickness will be lower than summer fuel when used at higher ambient temps and is similar to using the cold weather engine oils in desert heat
794764
Follow Up By: cookie1 - Sunday, Jul 28, 2013 at 12:00
Thanks for that, so in essence if I ran it on one tank it shouldn't be an issue but long term wouldn't be good as I would think that it may have insufficient lubricity during hotter weather- this of course is a mute point if they have changed the fuel by November.
794766
Follow Up By: garrycol - Sunday, Jul 28, 2013 at 12:51
Sorry Cookie - this is a
forum you have to take the relevant with the not so relevant.
But - no there is no issue using alpine diesel in warmer areas. The alpine additive is really just a variation of diesel (kero, heating oil or some other similar substance) anyway and just stops it waxing and burns along with normal diesel. I don't know where fisho got his information on lubricity from but I doubt there is an issue - afterall vehicles permanently using alpine for 6 months of the year in the mountains do not seem to have an issue.
Alpine would have probably stopped by November anyway.
794767
Follow Up By: cookie1 - Sunday, Jul 28, 2013 at 13:33
Thanks garrycol,
yep understand that it's a
forum but I have a tendency these days to not put up with irrelevant almost smart ass comments. The way I see it is - would I say that in the front bar of a pub with the guy stood in front of me :-)
I stopped coming to this
forum some time ago due to some people just being pretty non-constructive, rude & offensive but have come back and think that it seems to have changed for the better
If I can't comment on someones thread in a positive manner then I just leave it alone
Having said that I do appreciate the later comment / answer and undertsand that the original comment probably wasn't meant to be clever, just didn't answer my question
I appreciate the majority of people on this
forum and find it worthwhile coming on and having a look around
no offence intended to anyone
794771
Follow Up By: fisho64 - Sunday, Jul 28, 2013 at 17:41
mmm-dont know how you'd interpret my first comment as being "clever" but anyhow.
Garrycol-is diesel fuel the only mineral oil whose viscosity doesnt change with large temperature variations?
Note I didnt say it was "insufficient", just lower.
Why dont they just supply "alpine" fuel everywhere, rather than just in certain areas?
794781
Follow Up By: Honky - Sunday, Jul 28, 2013 at 20:41
Saw kero at $2.50 per litre at a BP Pump is probably why it is not added all year around.
Also talking to my Father in Law who used to work on Commercial ships and Kero was the mast dangerous fuel to pump onto a boat as it would heat up. It is also abrasive.
Honky
794795
