Charging 100AH AGM battery whilst under load
Hi all,
Have a 100AH AGM battery setup to run a fridge and lighting in a tandem trailer used to cart catering equipment to fire crews on the fire ground. The battery should have enough charge to run the fridge for approx 8hrs, the idea being that the setup will be run from 240V genset once on location.
What's the technicalities of connecting a 240V battery charger (e.g. Ctek) to charge the battery whilst it's being used to power 12Vequipment? Can it be done? Will it cause an error? The fridge is fairly simple to change over to 240V however at this stage the lighting is all 12V and would always need to run from the battery and not 240V?
Nick
